![]() Join Date: Aug 2006
Harrison radiator catch tank
Went to look at an ex accident/ recovery truck that originally belonged to a fire dept. I thought you all might have some feedback on these options. Nothing listen on the spid. Thanks, Lane |
Re: Harrison radiator catch tank
Cluster King
![]() Join Date: Nov 2012
The tank on the right fender well looks like one from an early (1962) Corvette.
If not it sure is close. |
#4 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Well from what I can tell,The first 2 pic looks like an old vette catch can,aka overflow tank.The 3rd pic is a throttle kicker used when the pto is engaged or other device,this is a seperate knob in the cab for this, they were usally red.The black relay with red sticker is next to the throttle kicker on the inner fender and that cycled it on and off. And the last pic is for the two battery hook up! It looks to have a heavy duty alternator that can run a power inverter also!!! That's just my 2¢, good luck
bowtiecharlie, where are you at in Quinton?
sent u a pm
