axle
I just bought a 1986 c10 chevy shortbed and I thinking about changing the drum brakes into rotors and and disc brakes is it worth to switch???
Re: axle
yes but you have to change a few other things. you cant just throw on a set of rear disks an call it a day. the master cyl. needs to be changed to a disk/disk set up plus change the proportioning valve
Re: axle
Worth it in what way?
Performance wise (daily driver): the production rear drums are sufficient. Most of the braking is done with the front on any vehicle, but in particular a pickup truck because of the minimal weight on the rear. Performance wise (race truck): maybe, but still limited by the above weight distribution and dynamic realities Visual impact: maybe - disc might be arguably more "attractive". Only you can decide on your truck. My trucks all retain the drums on the rear. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Re: axle
I agree with Keith. If it ain't broke dont fix it. I have not had a problem stopping with a these trucks. I would spend the dough for something you could use.
1979 ![]() 1996 Silverado x-cab "the daily" |
Re: axle
I'd leave it drums they last a lot longer then disc and cheaper to rebuild vs rear disc and pads will be.
Re: axle
thanks guys i was going to rebuild the whole rear break system. now with this information i will just put on brand new drum brakes and call it a day
Re: axle
also converting to disc can be a pain fabbing up an e-brake that actually works
