02-28-2013, 10:35 AM | #1 |
Crew Cab/ Suburban Doors?
This might be a dumb question, but will rear doors from a mid '80's Suburban fit in the rear of a '74 crew cab??? Thanks in advance
02-28-2013, 11:30 AM | #2 |
Re: Crew Cab/ Suburban Doors?
Yes, they are same with the door panels being different.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
02-28-2013, 12:14 PM | #3 |
sure will, just went the other way 2 weeks ago & put a '77 sub drivers rear door on my '85 crew.as rs72z says, door panels are different, inside door handle is also diff. if you switch inside handles, you'll have to slightly re-bend the door handle rod, door weatherstrip is slightly different also
03-01-2013, 09:55 AM | #4 |
Cool...thanks for the info. I found a couple of doors for about 50 each. Is that pretty cheap?
03-01-2013, 11:18 AM | #5 |
78K & 79C Jimmys
yup i sold mine for less
4 for 150$ late 70s use metal clips for the door rods, sometime in the 80s they changed to plastic holding the rods ends but parts do switch
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-01-2013, 11:20 AM | #6 |
Slots go on anything!
Price sounds good. You will not be able to run your '74 door panels on them. You could run 77-up panels on the fronts to make them match. Doors were redesigned in '77 to allow for use of power windows. The resulting changes called for a larger door panel to cover the bolts for the regulator and power door lock actuators.
