Old 02-28-2013, 10:40 AM   #1
379redneck
379redneck's Avatar
Will a 2010 14 bolt fit an 87
My friend got his hands on a 14 bolt rear out of a 2010 silverado, I was wondering if this would fit under my 87 because he thinks its a posi, we are gonna check it, and he will sell to me for 300, less than it would cost me to lock my 14 bolt sf. My main concern is the driveshaft
87 GMC Sierra 2500 4x4 350/TH350/NP203 Flow Tech long tube headers, throttle body spacer, Edelbrock Performer cam, true dual Flowmaster 40s, 6 inch Superlift suspension lift
2000 silverado extended cab stepside 5.3l. Stock for now
379redneck is offline   Reply With Quote
Old 02-28-2013, 11:55 AM   #2
low67chevy
Re: Will a 2010 14 bolt fit an 87
It will fit and the posi will be a g80 gov loc which is still a crappy posi at best r u sure it's a 14 bolt and not then 11.5 AAM axle? Is the truck a duramax?
low67chevy is offline   Reply With Quote
Old 02-28-2013, 01:02 PM   #3
rollinhard
rollinhard's Avatar
The spring pads will have to be moved and re welded on and the u joints will probably be larger than your 87. The aam 1150 is basically a 14 bolt just bigger. Same overall design
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 02-28-2013, 05:50 PM   #4
379redneck
379redneck's Avatar
I haven't seen it yet so i don't know. How do i tell the difference between them
Old 02-28-2013, 06:14 PM   #5
low67chevy
It will bolt right in not the 11.5 AAM it will need the perches moved the difference is in the diff cover design the 14 bolt has a smooth bottom and the AAM will have an almost pointed bottom of the diff cover
Old 02-28-2013, 06:15 PM   #6
low67chevy
You will also need the 1310/1350 conversion ujoint for your rear dshaft
Old 02-28-2013, 07:42 PM   #7
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Late model axles are also wider than your stock axle. 10.5 and 11.5 are the same width for the same applications (Dual, Single, Cab/Chassis). Best bet is to take a tape measure to your truck and to the axle and decide if the work and width is worth it to you. The factory g80s are nothing to write home about but they tend to live longer in 10.5/11.5 than they do in 10 bolts / 9.5s.
I run a 2005 11.5 in the back of my 68 K20 for the strength and disc brakes. There are some details in the build thread in my signature.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 03-01-2013, 02:39 PM   #8
379redneck
379redneck's Avatar
Does the 10.50 have the disc brakes on it too?
Old 03-01-2013, 05:05 PM   #9
low67chevy
http://www.pirate4x4.com/tech/billav...ble/index.html
Old 03-03-2013, 12:48 PM   #10
Mr. 250r
Mr. 250r's Avatar
It will not bolt right in i assure you, the perches will have to be moved. For mine which is a 2005 it was 3in wider than my semi floater that came out or 1.5 on each side. Do not be a hero and try to save the old perches and buy these http://www.ballisticfabrication.com/...ch_p_1485.html and cut the old ones just above the axle and grind them down. As far as the u-joints go im pretty positive after checking auto zones website a 2500 truck will have the 1350 while the 2500hd has the the 1410 which is the one i have and i can't find a jump joint from my old u-joint to the 1410 but since im having a driveshaft built that doesn't bother me. I also had a slight problem depending on how you look at it the aam pinion area ended up being 2in shorter than my semi float i checked this by looking at my slip yoke and now my drive shaft is basically about to fall out lol but for swb trucks that would help i guess.
To my knowledge the 14 bolt bible hasn't been updated for the aam axles
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 03-15-2013, 11:01 AM   #11
379redneck
379redneck's Avatar
This might be a rediculous question but, I took my 14 bolt sf apart last night with then intent to weld the spiders and found out its actually a broken posi. The little gear by the spiders has several areas where it's missing teeth (three spots missing about 8 teeth and one missing about 4) and the little piece that turns it is missing two of the four teeth it has. Would the carrier from the 2010 fit in my sf? Just throwing ideas around. I know the ring gears are different sizes
