Manifold question
I need to change the leftside (passenger side)manifold I need to know if 70s & 80s are the same.
Re: Manifold question
The 72 on back are completly different from the 73 up.
Not exactly. Two wheel drive and 4 wheel drive are even different with curved dump on 2WD straight down dump on 67-72's with 4WD. Due to clearance of the engine cradle and frame differences and stock engine positions. Then even some earlier years the alternator mounts to the l/h (Drivers side) manifold also. Provided the original configuration hasn't been changed over the years.
(Passenger side would be the right hand side as you sit in the vehicle while driving. This is the common way to determine which manifold you need.) That side is the one most prone to cracking.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
is this a right hand drive truck? // most vehicles in the UNITED STATES OF AMERICA are lefthand driver side
sorry for the mistake CDOWNS. I'm making fun of myself.
OK is the passenger side and yes the alternator is is on driver side
