Engine mount bolts
I've got a 66 c10 and stupid question but I can't figure out the dimensions for the engine mount bolts. Replaced the mounts and lost the bolts and don't have anything near what will fit. Just was wanting some insight before I go buy bolts. Thanks
Re: Engine mount bolts
which bolts? mount to engine, frame stand to frame, or mount to stand?
mount to engine are 3/8' NC X 3/4" (recommend grade 8) ( if a V8, if it's an inline 6 use these for bracket to block, then 2 - 3/8 X 1"NC with lockwasher and nut for top two mount to bracket, and a 3/8"X 3/4" NC for the bottom mount to bracket-it threads into a welded nut) for engine mount to frame stand- 7/16" X 1 1/4" NC with flat washer and lock washer, if a small block or a 6 cylinder. Big block with original type mounts uses a 7/16" X 2" NC bolt. Frame stand to frame uses 3- 3/8" X 1"NC with flat washers, lock washers and nuts These are not quoted from assmebly manual, just experience on what will work. I use nothing but grade 8 bolts on all engine mounts. hope this helps Last edited by tincan1966; 02-28-2013 at 05:31 PM. Reason: spelling |
#3 | |
