Old 02-28-2013, 07:24 PM   #1
sparky 69 3/4 ton
69 4WD disc brakes
any suggestions on 4WD disc brakes for a 69
sparky 69 3/4 ton is offline   Reply With Quote
Old 02-28-2013, 07:41 PM   #2
64swb
64swb's Avatar
Re: 69 4WD disc brakes
Swap in a '71-87 front axle, it will bolt right up and have discs.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4
64swb is offline   Reply With Quote
Old 03-08-2013, 02:28 PM   #3
danw210
69 K20
I would have to agree that you'll have less hassles if you swap in an open knuckle differential with discs already on it. However, if you do keep your differential it CAN be done. I am in the proccess of doing mine right now. I already had the differential blasted and powder coated, new knuckle seal kits, all new bearings put in it and THEN found out that my ideas for disc brakes were all wrong. Going they way of swapping the entire diff was an option but I already had too much invested in the closed knuckle. If you use spindles from a 71/72 and have your outer axle shafts turned down to 1.312" (where they fit into the spindle) it will work. If you can swap the entire diff I would recommend it but this is the way to make your current set-up work. Good luck with whichever you choose.
Here is my thread covering the closed knuckle disc brake scenario -
http://67-72chevytrucks.com/vboard/s...d.php?t=567022
danw210 is offline   Reply With Quote
