Old 02-28-2013, 09:27 PM   #1
rs74
rs74's Avatar
Flip kit question?
I am in the middle of putting the axle, springs and flip kit together. It seems that the axle will not seat down in the saddle due to the saddle legs being too long and bottoming out on the bottom side of the original spring perch. Drivers side is about 3/16-1/4" from resting in the saddle and the passenger is about 1/8" from resting. I assume that I need to take the saddles back out and start cutting them down until the axle rest in the saddle. I don't have a good way to cut them down. All I have is a cut off wheel on a 4" grinder. Here are some pics of the gaps. First two are drivers and next three are passenger. Passenger are kind of hard to see. Bad angle. Any advice before I start cutting. Do I need to cut equal off both sides of the saddle.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 02-28-2013, 09:37 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Flip kit question?
Grind them even and make sure they are not loose when the axle seats.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 02-28-2013, 09:43 PM   #3
cochino12
It followed me home?
cochino12's Avatar
what brand of flip is that?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-28-2013, 09:47 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
x2?
Keith
Convert to disc brakes.
Old 02-28-2013, 09:48 PM   #5
lolife99
lolife99's Avatar
Saddle "leg length", will also dictate pinion angle,...
Keith
Old 02-28-2013, 10:19 PM   #6
LEEVON
Moderator
LEEVON's Avatar
Could the leaf spring pin be too long? I wouldn't cut those with anything but a 4" cut off wheel on a grinder...
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-28-2013, 10:34 PM   #7
rs74
rs74's Avatar
Sorry guys I was out trimming the saddles down. This is a Western Chassis flip kit. I think I have them seated where they are supposed to be. Now I have a second question. These come with what they call the 6 hole plates that go under the axle. Depending on what direction I turn them the u-bolts either pitch toward the front of the truck or the rear. Once the bolt in seated in the plate it does not set straigh up and down. Whether the bolts are pitched towards the front or rear it is not that bad. Does this matter.
I still have it up on jack stands, so will the axle rotate one way or the other when on its own weight?
Roy
1987 R10 shortie
Old 02-28-2013, 10:41 PM   #8
lolife99
lolife99's Avatar
Look at the red circles.
The "offset" hole in the saddle goes towards the front of the truck.
The matching "6-hole" u-bolt plate, has a matching offset hole,... that also goes towards the front of the truck.
Keith
Old 02-28-2013, 10:45 PM   #9
rs74
rs74's Avatar
Thanks Keith. I appreciate that. Back out to the shed to snug it all up. I am supposed to wait until all the weight is back on it before tightening everything up right? The only thing on the frame is the cab. Should I just snug it all up and wait until after it is painted and get the bed and front end back on it to tighten it all up? This includes that I just put all new bushings in the leaf springs and saddles. Do I not tighten them up yet?
This kit didn't come with instructions so I am winging it. I had the saddle right. With the hole facing towards the front though.
Roy
1987 R10 shortie
Old 02-28-2013, 10:46 PM   #10
cochino12
cochino12's Avatar
keith you are the man, you always have a picture or a link to what we need.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 02-28-2013, 10:50 PM   #11
lolife99
lolife99's Avatar
I do alot of typing on Google Images.
The funny thing,... most of my searches lead me to the same website.
www.67-72chevytrucks.com.
Ha.
Keith
Old 02-28-2013, 10:52 PM   #12
lolife99
lolife99's Avatar
I think you will be fine tightening the u-bolts snug tight.
Then do the leaf spring and shackle bolts when you have ALL the weight on the truck.
(Bed and sheetmetal)
Keith
Old 02-28-2013, 10:53 PM   #13
rs74
rs74's Avatar
Awesome! Thanks!
Roy
1987 R10 shortie
Old 03-01-2013, 12:57 AM   #14
rs74
rs74's Avatar
Holy smokes! I am glad that is done. I got it all buttoned up and then realized the bottom shock bolt was put on from the outside in. So I had to take it all back apart and take get the bolt out and shock off then put it all back together again. I will put the wheels back on tomorrow, set it back on the ground and then start on the front suspension. Sure wish I had a lift to put the truck on.
Roy
1987 R10 shortie
Old 03-01-2013, 02:54 AM   #15
cory d
cory d's Avatar
ha i did the same thing but the bolt was rusty, i didnt want to deal with it so i cut it.
cory d is offline   Reply With Quote
