Old 03-01-2013, 11:38 AM   #1
naphtali5725
naphtali5725's Avatar
73-87 tubular control arm question
hey guys, i've got an 86 silverado, have a question...
any recommendations on a tubular control arm and or complete front end kit?
the whole front end suspension on my truck needs rebuilt, all rod ends/ball joints, control arm bushings, idler/pitman arm etc. etc.
was wondering if it would be easier and more economical to get a complete tubular kit, or replace all the components separately, press out the bushings and all that.
i'm pretty sure that i will only be doing a static drop at this point...
kind regards
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 03-01-2013, 09:40 PM   #2
DREAMER1
DREAMER1's Avatar
Re: 73-87 tubular control arm question
Personally I would go with aftermarket control arms. I'd shop around for a good deal, but even with a smoking deal you're still going to spend more than you would rebuilding your front end. It'll come out even cheaper if you did 100% of the work yourself. Even if its just a static drop, it just depends on you. Daily driver, weekend cruiser, etc
DREAMER1 is offline   Reply With Quote
Old 03-01-2013, 09:58 PM   #3
frog210
I ordered a set of tubular control arms from porterbuilt
little pricey but hey they look awesome and help over stock arms
they should be arriving in 2-3 weeks
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 03-03-2013, 04:13 PM   #4
Tyrfryer67
I'm in the same boat with the front end all needing to be replaced. I see a lot of people happy with porterbuilt control arms like frog210 said as well as a few other companies. Prices will definitely be more but if you pick the right setup you can improve handling and aesthetics both under the hood and by the wheel being centred in the wheel opening (win/win/win) for only a little more than rebuilding the factory stuff. I am adding a rack and pinion so I figure its better to just do it all at once. I am considering the nolimit engineering crossmember, control arm, r&p set up.
Tyrfryer67 is offline   Reply With Quote
Old 03-03-2013, 04:33 PM   #5
74 stepside
74 stepside's Avatar
Tubular is the way to go if you want to spend the extra $. You will also need an aftermarket swaybar if you go with tubular arms. Since factory swabars dont work with them. For a economical way, driver, just get a frontend rebuild kit.
74 stepside is offline   Reply With Quote
Old 03-04-2013, 02:51 PM   #6
G8DAN
G8DAN's Avatar
It seems that the porterbuilt ones are the fan favorites around here. Has anyone tried the CPP ones?
G8DAN is offline   Reply With Quote
Old 03-04-2013, 07:48 PM   #7
zook
zook's Avatar
Interested to hear the response about cpp.....parts, service?
zook is offline   Reply With Quote
Old 03-04-2013, 07:56 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
CPP makes a nice product for a coil spring set up.
They are powdercoated black, and help with camber and caster issues on LOW trucks.
I don't like their air ride arms, because the design of the lower arms only allows for a 2500 series air bag.
2600 bags are too big to fit.
Personally,... I would go with Porterbuilt arms for coils.
Because they can also be used with air bags if you change your mind later.
Plus they sell a Forward Series arm that helps center the front wheels in the fender opening,... on low trucks running a stock front crossmember.
They can also be order in a narrowed version, 3/4 ton and 1 ton arms, widened version for 1-ton dually running single wheel hubs and 22" semi wheel, etc.
The possibilities are endless.
Plus they are made to order for you with the correct balljoints.
Keith
Convert to disc brakes.
Old 03-04-2013, 08:20 PM   #9
naphtali5725
They are powdercoated black, and help with camber and caster issue on LOW trucks.
Personally,... I woould go with Porterbuilt bags for coils.
Yeah, I'm doing a static drop, and going with coils...but...would tubular and coil over's be necessary if I'm just doing a 2.5" drop spindles in front...or will the stock arms/springs be ok?
My build thread...
Disabled Veteran
Old 03-04-2013, 08:28 PM   #10
lolife99
lolife99's Avatar
Porterbuilt makes a bag/coil style arm and a coilover specific arm.
For what you are doing a stock set of arms will be fine.
I just thought you WANTED tubular arms.
Hard to read in everything in these posts.
PB arms will work with stock coil springs or drop spings.
You just have to tell Nate what you are doing when you order them.
I would also price the parts to rebuild your stock a-arms.
Balljoints, new crosshafts, and bushings, can add up.
Plus labor to install these parts if you can't do it yourself.
Keith
Old 03-04-2013, 08:36 PM   #11
naphtali5725
thanks for the info
tubular would be nice, but if they aren't necessary i'll keep the stock ones....but a rebuild kit for all the joints/rod ends/arm bushing etc. if i go with moog parts, man that's about 700.00+. and i'm sure i can't get tubular and all the parts for less than that. so i'm stuck with stock for now unless someone knows of a deal out there somewhere...
My build thread...
Disabled Veteran
