Old 03-01-2013, 12:25 PM   #1
Lattimer
Lattimer's Avatar
best fitting carpet
Who sells the best fitting carpet for our trucks?
I had wanted rubber flooring, and ordered one from LMC because that particular one covered all the way to the gas tank instead of leaving under the seat open.
Turns out it doesn't fit anywhere close. It looks like hell.
So, I am thinking I may just suck it up and go with carpet.
Who sells the best one? I see several from the usual places, and they all seem to be around $150. Are those decent?
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-01-2013, 12:48 PM   #2
cdowns
cdowns's Avatar
Re: best fitting carpet
it really depends on the skill and imagination of the person installing
Old 03-01-2013, 12:49 PM   #3
Mister-B
I wonder if the rubber is just shrunken up, because its cold this time of year? You may need to set in the hot sun when it warms up, or maybe carefully put it in the dryer in low with a towel and keep a close eye on it
Mister-B is offline   Reply With Quote
Old 03-01-2013, 01:04 PM   #4
Pine Bark Auto
I purchased that "Heavy Duty" mat for my 82 C10 from LMC and was very disappointed with the fit initially, but after working with it for a while, it is surprisingly well fitted but is cut a little large. I started with the indentions for the seat mounts and bolted a large washer there to hold the mat in place and then worked out from there. Go slow about making cuts. I left the sill moldings off for several days as the mat "grew" as the sun and heat of the day smoothed out some wrinkles. I used a heat gun initially in some areas, but be careful as it will really soften the mat. Chip.
Pine Bark Auto is offline   Reply With Quote
Old 03-01-2013, 01:04 PM   #5
CC69Rat
CC69Rat's Avatar
I like ACC, molded.. always had good luck with it.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-01-2013, 01:33 PM   #6
ChevyCruizer
17's too small
ChevyCruizer's Avatar
I installed a carpet in a 99 Suburban and it took at least 5 hours of trimming, yelling, and more trimming, plus all of the time to remove and reinstall all of the seats, belts, etc. Add a couple of bloody nuckles from trying to streach/mold everything into place. I can say that a "hot" carpet (Vegas summer time 100+) is easier to work with and make sure you use very sharp blades to trim everything.
As stated above, find the major molded area and work out from there. Maybe install a seat bold with a large washer to lock an area down and then move forward. But the little cab area in these trucks will be much easier to work with that a SUV.
Mine was a "el cheapo" and as I worked on it I promised my self that I would buy a factory carpet if I ever attempted another carpet job. But in the end it cost about 1/3 of the factory piece and now that everythin is installed and "settled" it looks great.
Thanks, John
68 C10 SWB SS 5 lug power disc brake conversion 2.5 inch drop spindles van tilt column Air Ride Technologies Cool Ride air bag kits Performance Online tubular upper control arms and shock relocator kits ECE super track panhard bar 1 piece side windows
ChevyCruizer is offline   Reply With Quote
Old 03-01-2013, 01:45 PM   #7
Lattimer
Lattimer's Avatar
I used a heat gun to heat it up and get the wrinkles out. The problem is the area around the gas pedal doesn't even come close and the fit on the hump is like its for a high hump. Way too much material.
I already cut this one, so it's junk now either way.
Shawn
Old 03-01-2013, 01:46 PM   #8
Lattimer
Lattimer's Avatar
With me, assume none on both counts. Hence the question.
Shawn
Old 03-01-2013, 01:47 PM   #9
Lattimer
Lattimer's Avatar
Who sells those ?
Shawn
Old 03-01-2013, 01:48 PM   #10
Lattimer
Lattimer's Avatar
Who sells those ?
Shawn
Old 03-01-2013, 02:21 PM   #11
dfwright
dfwright's Avatar
You can go directly to ACC's website, but I believe there are several board vendors and some major suppliers that resell ACC products.
http://www.accmats.com/
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 03-01-2013, 02:34 PM   #12
mrh33916
Project '67 454
mrh33916's Avatar
Check with you local upholstery shop. They may be a dealer and have the all the sample colors on hand to choose from. You would be amazed at how many shades of a color they have. Also, with the carpet code you can order extra bulk carpet direct from ACC.
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 03-01-2013, 02:56 PM   #13
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
We sell ACC carpets... WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-01-2013, 05:25 PM   #14
Wrenchbender Ret
I got my carpet from LMC & it is JUNK. It is all wrinkled around the heel pad. There is no heat in the world that would get it right. I have health problems & would have a hard time doing it over. Some of their parts are not even driver quality. They try to give you flex radiator hoses. I am close to them so it was convenent, but I will not buy anything for my Chevys from them.
Wrenchbender Ret is offline   Reply With Quote
Old 03-01-2013, 06:36 PM   #15
shearjs
shearjs's Avatar
I've read that trimparts.com has good carpetas well, but I'm not to that point in my build yet, so I can't comfirm that.
shearjs is offline   Reply With Quote
Old 03-01-2013, 06:55 PM   #16
CC69Rat
CC69Rat's Avatar
^^ Trim Parts and Auto Custom Caroets are in the same league IMO. I have used both.
Chad
Old 03-01-2013, 07:04 PM   #17
knomadd
knomadd's Avatar
I just installed trim parts carpet. The company said it would cover the old gas tank location. It covers about half of that location, not all the way to the rear cab wall. Still fits nicely. It still needs some trimming (behind the door jambs where the extended portion of the carpet is, and for the headlight dimmer switch on the floor) but otherwise it seems like it's good quality.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-01-2013, 08:21 PM   #18
Pine Bark Auto
Do you still have the box it came in? Mine was packed in a ACC box, which I assumed was a old carpet box. I didn't check for any numbers on the box. I didn't find out until much later that ACC makes the HD rubber mats also. I guess what I'm trying to say is, see if you can make sure the one you have is not ACC. Chip.
Old 03-01-2013, 09:30 PM   #19
Lattimer
Lattimer's Avatar
Mine was just in an LMC box.
I had to cut around the gas pedal area to even be able to install the pedal, and it still took a lot of heat to get it to lay down at all. The whole thing just sucks.
Shawn
Old 03-01-2013, 09:38 PM   #20
danheit
danheit's Avatar
I just purchased the ACC carpet set about a week ago, and am very happy with it. RockAuto.Com is by far the cheapest place I have found to get it. I bought the 80/20 loop with the massback insulation, shipped to my door was less than $150. I searched online for a %off coupon from RockAuto. ACC the company wanted nearly 230 for the same set! I was also able to choose the color I wanted, which wasn't a factory color, but went with the charcoal gray carpet.
1955 Chevy 3100 Task Force Pro Street - Sold!
1957 Chevy 3100 Task Force "Rat Rod" a.k.a. SLOTH - Sold!
1971 C10 Longbed factory A/C all stock 350/350
1979 Jeep CJ7 - Build date on the day I was born! -Keeper
2004 Expedition - Family Hauler
2007 Accord - Wife's around towner; I have more but not enough lines to post them!
danheit is offline   Reply With Quote
Old 03-02-2013, 12:11 AM   #21
Lattimer
Lattimer's Avatar
Cool. They do have good prices.
Shawn
Old 03-02-2013, 08:35 AM   #22
elf w/capital T
...i made my own before i started the restore. Home depot had a roll of looked like Exactly charchole grey car carpet, measured, measured, cut, fit, trim, and used tape and marked with sharpie on backside, epoxied, let dry and baaam, it looked great but i did spend tooooo much time on it.
elf w/capital T is offline   Reply With Quote
Old 03-03-2013, 10:36 PM   #23
72SWBChevy
72SWBChevy's Avatar
How was the fit? I need a carpet kit soon for my 72.
Some good prices on Rockauto.
Tks
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 03-03-2013, 11:14 PM   #24
Jarwood
Jarwood's Avatar
I just bought carpet from Sumitt. I believe its made by Lund. It fit really well with not cutting. It is a one piece and fit to the front of the gas tank.
Jarwood is offline   Reply With Quote
Old 03-04-2013, 12:59 AM   #25
austinstocker
austinstocker's Avatar
I bought a carpet kit from LMC in the past. I didn't have too many issues getting mine to fit, but it has become sun damaged since I installed it a few years back (black carpet). I would have expected that it would resist the sun a little better, especially being in western WA.
____________________________
1967 C10 SWB Big Block 4 Speed
austinstocker is offline   Reply With Quote
