Swap questions..
Ok.. well its been a while since I posted.. still check out these cool trucks and build threads regularly tho, some u guys are really talented... anyways here are my questions.. I have a 2 wheel drive 63 c10.. I wanna swap out to disc brakes and possibly auto column shift.. so what brakes and column would be a fairly easy swap? Thanks again for your time and keep up the amazing work on these trucks.._
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Swap questions..
71-87, all you need to do is swap the upper/lower A arms, spindle and brake stuff. Get the per steering from te same donor and get capt fans adapter for the gear box to frame and the per booster to cab.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
