Door Panel Question
I have a 72 but it has 71 door panels on it(previous owner). The doors have nutserts in them. Can I install 72 panels on it or do you think the doors where changed to 67-71 at some point. I'm completing a restoration on it so I want it to be fairly correct. Thanks
Posted via Mobile Device |
![]() Join Date: Aug 2010
Re: Door Panel Question
It's hard to tell without pictures but it should be fairly easy to switch door panels. Are you sure the doors are 72 correct? If they have the screw below the vent windows then I would say it would be easy to switch back to 72 door panels since the holes should already be there.
Also, WELCOME TO THE BOARD FROM NC!!!!
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
you will have to change the window regs and door latch stems they are longer for the 72 plastic door panels
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
They don't have the screw below the wing window so I guess they are not 72 doors. When I get to my regular computer I will post a pic.
Are you sure the truck is a 72 not a 71?
The vin and the title says it's a 72. Someone changed the doors apparently. Thanks for the replies.
