Old 03-01-2013, 05:14 PM   #1
Coach529
Coach529's Avatar
Chevy 3600 with Blazer Rear End....help!!
Found a newer GU6 coded blazer rear end that I wanna install.
My question revolves around the driveshaft/ rear end mating. I assume I will use my driveshaft. Is there a universal joint that attaches my driveshaft to the Blazer rear end?
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-01-2013, 05:17 PM   #2
focusedontheprize
focusedontheprize's Avatar
Re: Chevy 3600 with Blazer Rear End....help!!
Your running the SM465 transmission still?
Reason I ask is because if you have to get a drive line made (like I had to), just cut the end off the driveshaft for the rear end and bring that.
I am running a Ford 8.8 out back so I had to have it mate up with my NV3500.
focusedontheprize is offline   Reply With Quote
Old 03-01-2013, 05:20 PM   #3
Coach529
Coach529's Avatar
If that is the stock 3600 4 speed then yes. Enclosed back to hanger bearing then open.
1949 Chevy 3600
Old 03-01-2013, 06:01 PM   #4
NEWFISHER
NEWFISHER's Avatar
Should be a 1310 u joint at the rear, get the conversion joint to the blazer rear and you are done. Any parts store should have the number , or I can go through my reciepts
NEWFISHER is offline   Reply With Quote
Old 03-01-2013, 06:04 PM   #5
Coach529
Coach529's Avatar
My stock rear end is HO52 correct?
So I need a conversion joint to go to a HO52 to connect to the driveshaft, and the Blazer?
Is the Blazer u Joint a 1310?
1949 Chevy 3600
Old 03-01-2013, 08:44 PM   #6
NEWFISHER
NEWFISHER's Avatar
1350-truck to a saginaw s44 -Blazer. Carquest Scott 541-998-6882 P/N 2-1153 in stock and can ship to you.
sorry it took so long, that was a wierd one
Old 03-01-2013, 08:47 PM   #7
Coach529
Coach529's Avatar
Your the man Fish!!!
1949 Chevy 3600
Old 03-02-2013, 12:25 AM   #8
Coach529
Coach529's Avatar
Also to help others......a Precision #447.
My local O'reilly's had one in stock!!
1949 Chevy 3600
