Factory tach not working
Found a factory tach cluster on eBay. Putting it in my '86. Everything works but the tach! Bought new wiring harness from LMC for tach. One wire to distributor. One wire grounded. Other end had pigtail that didn't plug into my harness so cut off and spliced on male end plugging in directly to fuse panel. Plugged in to back of tach....nothing.
Thoughts? Bad tach?? No clue if it worked when I bought it, but was told it did. Posted via Mobile Device |
Re: Factory tach not working
It sounds like you probably have it connected correctly, but just to verify, the wire colors should be:
Black = Ground Pink = +12V connection to fusebox Brown (or White) = Coil/Distributor (TACH terminal on HEI) If that's how you have it connected and it still doesn't do anything then it sounds like you probably got a bad tach. |
verify its on the tach terminal of distributor and making good contact too, could be bad harness from LMC
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
78K & 79C Jimmys
stock the power came threw the firewall
but i wired mine to the cluster power pink striped i'd check the tach circut board too may have a cold soldier joint
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#5 | |
New tach from LMC. New tach wiring harness (HEI) from LMC Brown wire (connector on harness verified sound) to firewall (back outside) port on distributor. Pink wire to secondary "iGN" spot in fuse box. (Verified hot due to accessory flood lights plugged into other half of same port...lights work when turned on. Black wire connected to one of the gas pedal mounting bolts. Turned on for first time...tach twitched (old one didn't even do that). Turned over engine...tach jumped up to 2k and then back down to flatline What The Hell!?! Posted via Mobile Device |
#6 | |
78K & 79C Jimmys
the ground " bus" area by the ebrake might be better getting it to " zero" when powered is good aside from a bad unit , should go when hooked up as described but did any other tach work? Posted via Mobile Device
Moderator
![]() Join Date: Oct 2008
TACH tap off the coil is present? I've seen HEI with no tach terminal inside the cap.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Ok, ran test light. Started truck, probed TACH port on distributor...lit up. Probed fuse panel where I have it hooked up...lit up.
Up next...take apart dash...again...and probe other end of pigtail on back of tach? Posted via Mobile Device |
Double check your terminal on the wire at the dist. My crew cab drove me insane. I could start it up and it would run fine. Go to start t again, nothing but cranking. Swapped carbs, caps, modules, plugs, wires, everything but the tailpipe. Turned out that the brass part of the connector was loose, not loose on the wire, but the distributor end. The plastic was a tight enough to keep the power wire in the cap. Finally pulled the connector apart and crimped down the end and worked perfect. This might be your issue too.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#12 | |
Ran test light on 12v wire at tach end...test light said YES. Ran ground to bolt that goes through firewall under dash...scraped paint off under bolt to ensure good contact. Tach still is dead in the water!!! Called ...getting a new tach... Posted via Mobile Device |
#13 |
SOLVED: Factory tach not working
Installed new tach after a final verification that the wiring was good. Didn't work. I made up a few words you haven't even heard yet! Started playing with the two tachs, comparing new circuit boards to old tach (found a dark did colored spot on old...it was fried).
Long story short, the circuit board can only go on one way. Then you put the little washer over each of the 4 prongs, followed by the little lock washer, then the nut. Next put on the plastic backing that screws into the cluster housing by 3 screws...then plug in wiring harness to the three prongs sticking through the backing. Screw plastic backing into housing, then screw in the tach itself. My mistake? I put the nuts on the outside of the plastic backing to hold the tach to it...that was a bad idea apparently. The only thing holding that backing to the tach is the harness plug! Who knew!?! ![]() Posted via Mobile Device |
