1969 Custom 30 wrecker
I finally got my speedometer set accurately (took 6 years to get myself to do it)
![]() Mine is a 1969 C-10 short stepside with a 74 350/2 bbl and turbo 350. Rear gears are 3.73 and the truck weighs 3700lbs. I could probably have squeezed a bit more out of it but a few irritating drivers made me get on it 2-3 times during this tank full! ![]() This is around town mainly. Im afraid to check the big highways as I know the 3.73's would kill mileage. ![]() So hows yours? (remember, accurate speedometer first)
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Speedo dead on. 18.4mpg average on highway and city. Running between 30-80 mph.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
We get 15-16 miles to the gallon on the highway at 70 mph. 14
around town. Loaded or empty does not seem to matter. Jim |
Ok,
454, Th400, 411's, and 35's... I got 11 keeping it in the primarys for 150 miles. Around town 7-9 cleatus
"What we are dealin' with here is a complete lack of respect for the law...." Beuford T. Justice |
Mine seems to use gas even if its not running, and when it is running it uses even more. Plus I got 4:10's
Weapons Of Construction
After keeping all the receipts with the miles written on them, I put them into excel. Hovering in the 10 to 11 mpg range consistantly. The pipes sound best when I'm standin' on it!!!
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
![]() Join Date: Jan 2001
I get 10 with the the 402.
![]() Join Date: Jun 2003
Oh Boy! How about 8 mpg in the city or on the highway, rolling tall or pulling a long haul.
But then again, it's 337,000 original miles on an mildly tired 350. We currently have 4:11's. on 40" Tires. |
Got 20's????
15.4 going 65 and 12.5 going between 80-100mph. 3.73's w/ overdrive.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
About 11 mpg. 3.08 gears, fresh rebuild, not to big of a cam. I gotta rejet this edelbrock carb, I think I could squeeze out a few more based on what everyone else is getting.
How do I check the accuracy of my speedometer? Would love to know (I think) what my gallons per mile is.
67 Fleetside Shortie, small window, slip & slide tranny Upgrades--small block, tilt column, disc 5 lug conversion (front and rear), Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG) |
/me nods and uses 5 gallons per run on the 1/4 :grin: The ole 350 gets around 10, and im poor, so it dont get out much
#13 |
What kind of mileage can I expect out of a 6 cylinder 250?
#14 |
MINE GETS ABOUT 20MPG. 3.54'S OUT BACK. TREMEC 5-SPEED AND TBI ON A 327
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
#15 |
I am lucky if I get 7-8 in town. The 4.11's and aftermarket stall do not help matters any. I have not driven it on the freeway since I got done working on it. It will probably rattle apart.
http://photos.yahoo.com/cruzn72@pacbell.net |
#16 |
now thats a true COON DOG
![]() Join Date: Nov 2000
Just started up my freashy rebuilt 402 tonight so I'm not sure what I'll get for mileage or what to expect.... But I'm really hoping for 10 mpg...
current project 67 ![]() 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) ![]() 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
#17 |
newly minted old timer
poor mans way of checking speed go. go up to the highway and put it at 60mph. get the passenger to start a stopwatch when you pass a mile marker.. keep it at 60 till you hit the next marker.. should be 60 seconds.
i seem to be getting 10 or so with my 350 auto trans..373s... i did get 17 when i moved to texas .. that was on the highway at 50.. wish i could get that all the time.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
#18 |
SKINNY TIRES RULE!
My speedo is way, way off. But I'm estimating in the 6-8 mpg. My carb is a little messed up though. I've got another doner that I'm going to rebuild and see if it works better.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#19 |
Jayssun, check your speedo against a portable gps.
Cheers Richard
Broken Arrow, OK. 1977 Corvette, ZZ4 Crate, new interior, new suspension, new driveline, you get the picture, (new project / daily driver) |
#20 | |
14.1 @ 96MPH
Project1970 - LS1 Swap Complete! ![]() |
#21 |
THE QUICKER FIXERUPER
I get about 8 mpg with my non stock 327
![]() Gee_Emm I got 11 out of my 250 with same gears |
#22 | |
#23 |
Formerly yellow72custom
13 mpg going 75 on the highway. 350/350/3.07 gears. It would proably get 14-15 if i were to keep my foot out of it and drive 60-65 mph.
I don't have to warm up my truck very much at all. I have my electric choke tuned pretty good, so i pretty much start it up, put it in gear and drive off. It may die every now and then if it has only run for 10 seconds, but usually goes just fine. From my experience, electric chokes work great, but the old divorced choke Q-jet i had worked like crap, and i had to sit around and warm it up.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#24 | |
Hot Damn - Here I Am!!
My advice is to go with the V8 Gee_Emm. Robert
My vehicles: '90 Silverado Sport '71 Chevelle SS Convertible '70 C-10 - My Grandfather bought it new - original un-restored |
#25 |
Gas mileage!-what's that? (3.07 with a 502)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
