Boosting an inline 6
I know this sounds a little different but i want to turbo my 235 chevy stovebolt. It is in a 58 chevy apache longbox sm420 with factory rearend. the motor was rebuild 3 or 4 years ago and was used in a hay sweep and is still a good running engine. I have heard that on a stock motor you can run under 8psi boost, so i have since acquired a turbo off of a 3406E Caterpillar and wonder if i can back the waistgate off to about 6psi and the motor still be able to hold.
![]() Join Date: Nov 2011
Re: Boosting an inline 6
I wouldn't run boost without forged pistons. Even at low psi I've heard there can be detonation and cast pistons being destroyed.
J'aimi 54 Chevy 3100 5.3/4L60E (Plan to make summer daily driver) 54 Chevy 3600 "Destiny" future project (Plan to build for my daughter) 72 C10 current daily driver 74 Nova Son's DD (His 1st car, we had to start him off right) 00 F*rd Expedition wife's DD (She's the trader in the house and doesn't drive a GM ![]() |
Check out Tom at. 12bolt.com and look for the video link. The manifold he is using is a factory austrailian piece.
Posted via Mobile Device |
Square
check out the racing and performance section of the forum. those guys can help for sure
here is a LINK
Squarebody Syndicate |
polishing a turd
I considered this previously. The cast pistons are the first holdback.
Make sure you have a good fuel pump, manifold referenced fuel pressure regulator, a carburetor modified for blow through applications, and keep the boost low by using a large waste gate. I built a system for my ford lighting, but it is a totally different animal. Posted via Mobile Device
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
