![]() Join Date: Oct 2006
Fuel puddling?
What would cause fuel puddling on top of one of the butterflies> 454 TBI. Thanks
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
Addicted to Rust
![]() Join Date: Dec 2009
Re: Fuel puddling?
Dirty injector?
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Re: Fuel puddling?
So where would be a good place to send the injectors to get cleaned?
Re: Fuel puddling?
the injector squirts gas when the blades are closed the vaccum sucks the gas past the narrow opening helping it to atomize.
key on the injectors give a squirt do the injectors drip? remove air cleaner run truck then place a piece of paper you see on paper if their dripping how does the truck run at idle if it does not sputter i dont beleive there bad you can also use a dialback timing timing to shine at the injector spray pattern this is where you will see a bad injector the pattern will not appears as a cone and the gas will stop then restart spraying |
