Old 03-02-2013, 04:11 PM   #1
Jhogan63
Jhogan63's Avatar
Vintage Air Radiator Question
I am ready to bite the bullet and order a Vintage Air kit for my '63. My original radiator is shot and is held together with Stop Leak so need to replace that too. What is the best radiator for the $$ that is a direct bolt in for use with my application? Crate 350/350 turbo and A/C.
Thanks for any help:
Jhogan63 is offline   Reply With Quote
Old 03-02-2013, 05:52 PM   #2
65Gregg
65Gregg's Avatar
Re: Vintage Air Radiator Question
A lot of forum members talk about the Champion brand off of EBay, you might check with the forum vendors like Pro Performance.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 03-02-2013, 08:13 PM   #3
TopFuel1966
TopFuel1966's Avatar
My Mattson radiator was made to bolt directly to the core support for a no-hassle installation. I didn't have to re-engineer anything to make it fit. It came complete with a trans cooler, a/c condenser, an electric fan with a shroud, a bung for the fan thermostat, and even a steam line connection for a EFI motor.
http://www.mattsonscustomradiator.com/chevrolet-trucks
TopFuel1966 is offline   Reply With Quote
Old 03-04-2013, 09:14 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have a champion, it bolted right in but did need some tweeking of the rubber in the mounts. everything else fit perfectly and cooled my truck well.
TopFuel, what did that rad set you back?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-06-2013, 03:07 AM   #5
TopFuel1966
If I remember correctly it was around $800.00.
Old 03-06-2013, 09:46 AM   #6
tincan1966
tincan1966's Avatar
I have used www.Alumarad.com in the past- good fit and decent price- direct bolt in for '63-'66 is around $240 with trans cooler.
tincan1966 is offline   Reply With Quote
