Old 03-02-2013, 04:53 PM   #1
StrokinRat
StrokinRat's Avatar
What do I have wrong?
As you can see from the picture that my radiator hose is running on top (touching) my a/c hoses. I know this isn't right but not sure if its the wrong hose, wrong thermostat housing (I have to get a new one b/c that one busted) or I have something ran wrong. Any help and/or pictures would help.
85 Chevy C-10 383 stroker
StrokinRat is offline   Reply With Quote
Old 03-02-2013, 07:10 PM   #2
rs74
rs74's Avatar
Re: What do I have wrong?
This is how my 85 with 350 was run before I tore down for the build. My radiator hose went under the AC hoses.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-02-2013, 07:11 PM   #3
rs74
rs74's Avatar
Looks like your AC lines are run opposite of mine.
Roy
1987 R10 shortie
Old 03-02-2013, 08:04 PM   #4
pwradder
pwradder's Avatar
that looks like a retrofit compressor and lines, could be the source of the interference problem. you may be able to get around it by bending the a/c lines (risky) and running the radiator hose under them-like in rs74's pic. or i believe there is a spacer available that raises the height of the thermostat housing- that would get the hose off the lines, i would check summit for that spacer.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold
1986 suburban 350/700r/3:73's 31's: parted out.
1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold
1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold
1970 c10 long bed-new project! getting ready for the 6.0
pwradder is offline   Reply With Quote
Old 03-02-2013, 08:24 PM   #5
LONGHAIR
It looks to me like someone bent the lines forward and ran the radiator hose over them. Trying to re-bend them at this point is not only risky in terms of ruining the lines, it's downright dangerous.
Most things like that will bend once, bending it back will crack it.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-03-2013, 08:25 PM   #6
StrokinRat
StrokinRat's Avatar
Thanks guys. After some more research I have came to the conclusion that the A/C lines have been bent and I will be ordering new ones. After talking to my dad he reminded me that there wasn't a compressor on the truck when I got it and that the hoses were just laying on the inter fender. That's why I didn't remember if the radiator hose were touching the lines before. I only had the truck like a week before we pulled the motor. Thanks again.
Old 03-04-2013, 09:00 AM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Use an 88 and up water neck. Later model necks are angled higher to clear a serpentine belt. I use a 94 water neck on my truck. I had to build a support to hold the hose up. I didn't like it bouncing up and down.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
