Old 03-02-2013, 05:26 PM   #1
cmyc5575
Mechanical question on an 83 gmc shorty?
I noticed that my driver side wheel has some negative camber is what it think its called or where the top of the tire is sticking further out of the fender than the bottom of the wheel. How do i fix this?
cmyc5575 is offline   Reply With Quote
Old 03-02-2013, 06:18 PM   #2
krazy_texan
krazy_texan's Avatar
Re: Mechanical question on an 83 gmc shorty?
I would just take it to an alignment shop and let them fix it
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 03-02-2013, 06:35 PM   #3
cmyc5575
Ok, lol I think that will be alot easier. thanks
Old 03-02-2013, 07:49 PM   #4
LONGHAIR
Hold on.... how about some details first?
Does this truck have fairly big tires? Like 35s or more?
Lifted? How much?
The tires should have some positive camber (tire out at the top). Bigger tires make this more noticable, especially of they stick out of the fenders more. What you are probably seeing is the fact that something is wrong with the other side, letting it tilt in(negative). It could be as simple as a worn ball-joint, bent spindle, or more serious like the entire housing is bent.
A loose ball-joint should be fairly easy to check. Jacking that wheel up enough to wiggle it by hand should tell you. The others may be less obvious.
Either way, the best you can hope for at an alignment shop is just checking it out. Unless you live in a pretty big city that actually has one this specialized, they aren't going to be able to do much for you.
If is does turn out to be a ball-joint, simply replacing it cures the problem, no re-checking needed. Bent spindle, same thing, replace and move on.
There is no "adjustment" for this spec. It is all "built in" to the housing....as long as all of the parts are tight and un-damaged, it's fine.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-02-2013, 07:58 PM   #5
cmyc5575
Lifted? How much?
Stock heigth and stock wheels are on it right now. Its got the wheel sticking out at the top. Im no proffesional mechanic but i dont think that its suppose to have that much tilt out at the top. heres a picture of the truck.
Old 03-02-2013, 08:11 PM   #6
LONGHAIR
Sorry, I wasn't paying close enough attention. I had it in my head that I was in the 4x4 section disregard the above and take it to an alignment shop....lol
Old 03-02-2013, 09:57 PM   #7
cmyc5575
Lol oh ok thanks for the info and reading this anyways.
Old 03-05-2013, 07:25 PM   #8
cmyc5575
Update to my truck wiring today. I went to head to the store yesterday and the brand new battery that I bought for it was dead and started tracing wire today. As you already know the wiring is a mess so far but I found this today and was so happy to found the problem.
Name:  Truck battery wire.jpg
Old 03-05-2013, 08:01 PM   #9
cory d
cory d's Avatar
ha i did that to my positive about 6 months ago........i should probably do something about thats. nah i'll wait until i relocate the battery
cory d is offline   Reply With Quote
Old 03-05-2013, 08:18 PM   #10
cmyc5575
Yeah I'm thinking that I am going to have to get a longer battery cable bc this one is stretched enough.
