Old 03-02-2013, 08:10 PM   #1
msg
Instrument panel lights up but not much more
On my 66 I have an instrument panel that the only gauge that kinda works is the fuel. On a full tank the needle goes to F but towards a half tank it bounces back and forth.
I have no tach, vac or clock in the cluster, just the usual.
What steps do I need to take to check each gauge?
msg is offline   Reply With Quote
Old 03-02-2013, 08:19 PM   #2
mark 66
Re: Instrument panel lights up but not much more
Check the wire where goes under door sill plate to tank. if that wire is rubbing cab it will cause a ground issue and cause guage to work funny.
mark 66 is offline   Reply With Quote
Old 03-02-2013, 09:33 PM   #3
msg
Thanks for the tip! I'll check that tomorrow.
Any tips on the other gauges that are not working like the speedo and battery and temp?
