Old 03-02-2013, 09:58 PM   #1
Boss hawg
Corvette IRS with air
I've tried searching the forum for this with little results that I can find. Has anyone run a corvette IRS with air? If so I would like to hear or see some of the set ups
Boss hawg is offline   Reply With Quote
Old 03-02-2013, 11:20 PM   #2
andrewmp6
Re: Corvette IRS with air
A few people have the porterbuilt c4 rear which is on air.
andrewmp6 is offline   Reply With Quote
Old 03-02-2013, 11:34 PM   #3
Boss hawg
I'm thinking that is for the front on the c4... I'm not sure but all the porterbuilt setups I see on the rear are on a solid axle.
Old 03-03-2013, 12:04 AM   #4
andrewmp6
He had a rear one talk to nate.
Old 03-03-2013, 11:33 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes, Porterbuilt has a Vette suspension. Here one he built a few years back.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-03-2013, 11:51 AM   #6
Boss hawg
That's a wild setup... Pretty sweet looking! This leads to my next question. Is it set up that way because its designed to lay out? Could the bags be mounted like a shock setup and still get fairly low or is there an issue with doing it that way. My idea was to set it up that way but my buddy seems to think with the half shafts and 4 link set up that it would bend the links after the shafts reach a level plane.
Old 03-03-2013, 12:18 PM   #7
Boss hawg
I'm gonna go out on a limb and say it looks like the 4 link has swivel eyelets and that's why....does it push the wheels far enough outward at level plane that you would need to modify the fenders?
I guess I should have included that my installation would be on a 54 chevy.
Old 03-04-2013, 03:08 AM   #8
andrewmp6
That frame is under his blue truck its a 50s i can't remember the year off the top of my head.Talk to nate he can give you any info on it better then any of us.
Old 03-04-2013, 01:43 PM   #9
ddubbs
ddubbs's Avatar
I believe this frame Nate built for N2Billet. It was for a Chevy C10 pickup. Anyways Nate would be the person to answer all your questions.
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
Old 03-04-2013, 01:45 PM   #10
Boss hawg
I sent him a message he just hasn't responded yet.
Old 03-04-2013, 02:48 PM   #11
ddubbs
ddubbs's Avatar
Boss Hawg I bet they are backed up at the shop. I have seen several post of people that bought crossmembers from them in the last month. Be patient and he will get back to you. Hopefully he can help you out still.
Projects
Old 03-04-2013, 02:54 PM   #12
Boss hawg
I am... I'm not completely ready to do the rear yet I'm still researching so I have time. I'm still working on the front at the moment. I just like to make sure I'm at least close to being on the same page before I start something!
Old 03-04-2013, 04:04 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
It might be a day or two until I am able to reply to your PM. I will get back to you though.
Crazy busy at the shop, and I am out there welding up parts!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-04-2013, 04:56 PM   #14
Boss hawg
Thank you
Old 03-04-2013, 04:59 PM   #15
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Yes, hitting the fairways in 75* degree AZ weather... oh, I mean WELDING up parts can be a nightmare!.... jk
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 03-08-2013, 03:54 PM   #16
98layinframe
98layinframe's Avatar
Nice looking set up! Is the front suspension cross member a pb made or is it a progressive or flat out one by chance?
Why arent these available to order setups!?
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 03-08-2013, 04:17 PM   #17
PBFAB.COM
PBFAB.COM's Avatar
All stuff I designed and built.
In regards to them being "available to order" we have just been too busy with everything else. There isn't a high enough demand to take the time away from building other products. Maybe one day we will have something similar that will be a production item. Just not anytime soon.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 03-08-2013, 06:09 PM   #18
jimmydean
jimmydean's Avatar
I still wish I could go this route but the cost of the shockwaves put things WAY over budget. Still a sick setup.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-17-2013, 02:18 PM   #19
Boss hawg
Still could use some help on this... My question about using the shockwaves in original shock mounts(the lower anyway).
Old 03-18-2013, 02:24 AM   #20
andrewmp6
I did some digging http://www.progressiveautomotive.com/sweetair.htm going by them you just need to make the upper mount.
Old 03-18-2013, 09:03 AM   #21
Boss hawg
I was wondering how low you could get though with that set up. I don't care if it lays frame. I noticed the porterbuilt set up is cantilever and the 4 link has hiem joints. I was curious is it had the hiem joints because of the half shafts pushing outward at a level plane? Would it bend the links without them if it were at level plane. And also if the fenders need to be modified with the half shafts at level plane on a 54 truck.
