Shifter Recommendations
I have installed a LT1 out of a 1995 Buick Roadmaster in my 1958 Chevy Truck - step side. It has the 4L60E transmission. I was thinking about getting a center console with floor cable shifter to use. Will this work? Any donor vehicle recommendations? Any other ideas? pictures would be great - Thanks in advance.
Re: Shifter Recommendations
you could always look at a floor shift auto Camaro, Chevelle or pretty much any 70's car that had an auto floor shift in it. You'll find all the parts you're looking for
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Jul 2007
I'd want to do a bit of research on what vehicles had that transmission that had factory floor shifts in them. That shouldn't be real hard and some may have a better looking shifter in them than others.
One possibility that should be fairly easy to find would be the second generation S-10 Blazer style rigs that came with that trans. You may end up building your own console though to get one to fit right.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 03-03-2013 at 02:10 PM. Reason: SP error |
My lokar works great
Posted via Mobile Device |
Thanks - the blog searches are interesting. I will continue to search. I do not want to cut a large hole in the floor board removable pan. Thanks all
