03-02-2013, 10:15 PM | #1 |
Rusty Nuts
can not find the proper antenna
Çan some one tell me where to buy the proper antenna. I have bought three different ones but they all have to much angle. And I believe this is the proper original spot on my 67. And cant find the one I took off.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
03-02-2013, 10:44 PM | #2 |
Re: can not find the proper antenna
i dont think that is the factory hole if i remember there should be a notch in the hole and looks to be too far forward on the cowl
btw thats a nice truck you are building
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
03-02-2013, 10:58 PM | #3 |
mine has a lot of angle as well. Going to be taking the aftermarket back off and go with a window mounted setup and plug the antenna hole on the outside.
03-02-2013, 10:59 PM | #4 |
Cluster King
I have the same problem. I will be looking for the correct antenna for my 72 soon. AM radio. Here is a photo of what I have now. This is in the correct spot, just wrong antenna.
03-02-2013, 11:38 PM | #5 | |
OP, I think you're in a tough spot, where the hole wasn't drilled right Posted via Mobile Device |
03-03-2013, 08:33 PM | #6 |
Rusty Nuts
Dad bought this truck new and it had the same cowl and antenna until I took it apart to paint but the mast was broke so I guess I through the antenna away. So I know the hole has never been changed. I did order one from manes truck parts but it has the wrong angle on the base. I guess I will just keep searching thanks people.
03-03-2013, 08:57 PM | #7 | |
Cluster King
