oil pan hitting crossmember
after installing a 509 big block in my 72 c10 2wd i noticed the oil pan just about hitting the front crossmember.i have seen guys notching the crossmember but has anybody shimmed the motor mounts? i just need a quarter inch.i gave up trying to find a different oil pan.thanks
![]() Join Date: Jun 2012
Re: oil pan hitting crossmember
What pan are you using???
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
#3 | ||
"I ain't nobody, dork."
Are the motor mounts for a BBC? Are the stands in the correct location?
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
my truck is a old drag racing truck it had a 468 cu in motor that was blown up.the oil pan rubbed a little bit with that motor in it.i think it has the original chevy oil pan.not sure on the mounts, good question i will have to find photos of small block and big block mounts/stands and compare.the mounts look factory.thanks for the help i will try to post photos.
if it is only a quarter inch or so?? me i would take the torch get the bad area of crossmember cherry red and a nice large hammer and clearance the thing with a nice even relief/// oldschool modification been done like that for as long as i can remember
#6 | ||
Nothin' like a torch and a BFH...
![]() Gary
thanks cdowns i will try and find a photo on a build thread of how close the pan is on other members trucks.
thanks GASoline 71 your right the po installed the big block on small block mounts,i did not notice till i saw a thread on the subject and saw the motor sitting up higher than mine.
