Old 03-03-2013, 08:47 AM   #1
hvychvy_72
airbag pressure drop when tank pressure drops
Im not thinking this is right. I have smc elec valves. I can air the susp to 140psi on all four corners and go and drain my air tank and the bags drain air with it. Shouldnt the bags stay up even if the tank is at 0psi.the valves dont need check valves do they. I did have to disasemble the valves to redo my orignal valve routing could I have assembled the valves wrong. It airs up just fine just losses air to the bags when I drain the tank.
hvychvy_72 is offline   Reply With Quote
Old 03-03-2013, 07:30 PM   #2
broey
Square
broey's Avatar
Re: airbag pressure drop when tank pressure drops
either the valves are bad, or hooked up wrong. also, check the one way valves at the compressor.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 03-03-2013, 07:51 PM   #3
Jayschevy
If the bags loose air when the tank looses air, you will need to add a check valve between the tank and the valves. The check valve flows air in one direction to the valves and bags but prevent the air from flowing back into the tank when the tank loose air pressure.
Jayschevy is offline   Reply With Quote
Old 03-03-2013, 07:57 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
This is normal with most electric valve set ups. They use back pressure to keep them closed. One would think this doesn't make sense.... But that is how they are designed.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-03-2013, 11:04 PM   #5
hvychvy_72
Thank you guys for the replys. I just thought it was strange that the bags would only keep the same pressure as the tank and they are branr new. Sounds like I need check valves. Thought I would ask before I took it on its maiden voyage and if I lost air from the tank for sone reason I didnt want to wipe out my bedsides since I have no rear bumber at the moment. Where is the best spot to get some nice compact check valves?
Old 03-04-2013, 01:50 AM   #6
king-918
king-918's Avatar
Nate
Agreed
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 03-04-2013, 01:50 PM   #7
Jayschevy
There's many check valves out there. I'm using these..
http://www.avsontheweb.com/product.p...0&cat=0&page=1
Old 03-04-2013, 11:45 PM   #8
STPrider
STPrider's Avatar
So you would put a check valve between the tank and the valve block, correct? Does anyone know if this is how Accuair valves work?
'71 GMC pickup; "Ashley,"
STPrider is offline   Reply With Quote
Old 03-05-2013, 08:23 AM   #9
Jayschevy
I'm not sure about Accuair, but you will need a check valve between the tank and air valves.
