Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-03-2013, 09:37 AM   #1
58chevyman
Turbo my inline?
I know this sounds a little different but i want to turbo my 235 chevy stovebolt. It is in a 58 chevy apache longbox sm420 with factory rearend. the motor was rebuild 3 or 4 years ago and was used in a hay sweep and is still a good running engine. I have heard that on a stock motor you can run under 8psi boost, so i have since acquired a turbo off of a 3406E Caterpillar and wonder if i can back the waistgate off to about 6psi and the motor still be able to hold.
58chevyman is offline   Reply With Quote
Old 03-03-2013, 10:51 AM   #2
58chevyman
Re: Turbo my inline?
I am also thinking of using a blowthru set up with one or two 2gc carbs
Old 03-04-2013, 02:54 PM   #3
58chevyman
Or would a suck thru be better??
Old 03-06-2013, 06:18 PM   #4
58chevyman
any opinions anyone?
Old 03-09-2013, 10:11 AM   #5
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
well look up www.falconerengines.com, good friend ,... he has gone 300 mph on twin turbo in line 6 that he builds . Cool guy and he has more than enough info for you. I will warn you dont try to tell him what you know and how its needs to be done. if you do well you will hear a click on the line. This guy is the real deal. Tell Ryan I said hello.
GMR-PERFORMANCE is offline   Reply With Quote
Old 03-30-2013, 10:12 AM   #6
longbed67
longbed67's Avatar
You have a LOT to start thinking about when going with a turbo setup! I dont know your experience with turbo's... but a turbo off of 14.6L engine will NOT boost your 235 cu in motor! you might start to build 1 psi at redline with that turbo. You can check out my build thread for turbo specs, or start looking on theturboforums.com to start your research. on a 235 you will want a .59-.63 a/r exhaust housing with a mid 50's trim turbine. you will have full boost by 2500 rpm and can limit your boost level with a good wastegate, you will want to go blow through. Yes draw thorough (not suck through) can be done with superchargers, but with a turbo setup your carb will turn to a solid ice block. If you are new to blowthrough carb tuning, only go with a single double pumper carb setup as this is hard enough, and to try to sync two carbs would be difficult for even the most experienced tuners. Good luck and welcome to the boosted world!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 03-30-2013, 08:24 PM   #7
cubber
Research, research, research. I wanted to turbo my 250, but sold it and went with a 383 stroker because I wanted to go fast, and sound mean. Listen to Adam (longbed67), he has done his homework and really knows his stuff. Also do a search on a guy named Boucher, and his "Turbo JED" build. I've met him, and seen the truck, and they're both awesome. Get Leo Santucci's Inline Power Manual. If you want to have a turbo inline for the uniqueness, then more power to ya! if you just want to have a more powerful truck, swap in a v8. Inline power is really expensive. It's also really cool. You just have to decide what your real goals are!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 04-01-2013, 09:54 AM   #8
58chevyman
Hey longbed67 i dont know much about turbos but i have ditched the giant turbo and was wondering if a gm turbo off of a 6.5td would be more the style im looking for since there are about 7 or so sitting in a local junkyard. Also these turbos come with there own wastegate for the 6.5 limited to 8 psi are these a reliable unit? I also have decided on a single carb but how big should it be considering the stock 235 just had a single rochester b.
Old 04-01-2013, 07:09 PM   #9
longbed67
longbed67's Avatar
reliable yes, still WAY to big! even most of the holsets off of the cummins are way to big! and the holset specs are hard to get,Before you continue to jump on the turbo bandwagon and end up dumping a lot of money on things that may not even be right for your setup, you need to do some serious research on the different types of turbos, flanges, wheels, center sections, trims, housings, and what size works best for your target boost level and powerband, and become educated on what you are doing. If you have the cash to fork out for someone else to do it for you, I would gladly build you a kit for your set up as I have done for many others. I have provided some good starting points as far as size to look for above, if you deviate outside those specs you better be ready to either fry your turbo, engine, or both.
Adam
(608) 214-8706
Old 04-01-2013, 10:48 PM   #10
84chevyguyid
If you want to learn about turbos, get on The Turbo Forums, thats where I learned all the stuff I needed to know and built a twin turbo system on my 72 vette. Tons of information on there.
84chevyguyid is offline   Reply With Quote
Old 04-02-2013, 05:39 PM   #11
longbed67
longbed67's Avatar
Adam
(608) 214-8706
Old 04-03-2013, 06:44 AM   #12
D13
D13's Avatar
Join inliners. This has been discussed (and done!) over there many times.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
