Old 03-03-2013, 11:37 AM   #1
kevmic28
kevmic28's Avatar
trouble shooting drum brakes
I have an issue of the brake peddle moving too far when I hit the brakes and the truck doesnt brake very well. I have replaced the master cylinder, wheel cylinders, new brake hardware, new adjusters, I have replaced everything in the brake system but the drums. Bled the crap out of the brakes but nothing seems to help. I have no idea if the drums are original or not so they may be way out of spec but I need some ideas before I throw more money at it.
I have no signs of the wheel cylinders leaking either.
Im thinking a bad master cylinder or drums too far out of spec.
Any other ideas would be appreciated.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 03-03-2013, 12:33 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: trouble shooting drum brakes
Sounds like they need to be adjusted.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-03-2013, 12:38 PM   #3
Sammy
Agreed. If the drums are true then adjust them out more. Also insure the drums are clean where they make contact with the shoes. Sometimes they shoes need to seat for the drums after replacement.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-03-2013, 12:49 PM   #4
kevmic28
kevmic28's Avatar
They are adjusted. They feel better since I added the new hardware and adjusters but not good enough. Also this is something I have been dealing with since I got the truck in 2009.
1970 GMC truck
Old 03-03-2013, 12:49 PM   #5
geezer#99
geezer#99's Avatar
Did you replace the m/c with one the same bore?
Do you have the brake rod that attaches to the pedal in the upper hole?
Old 03-03-2013, 01:27 PM   #6
kevmic28
kevmic28's Avatar
I have another MC laying around. I am going to swap them and see if it makes a difference.
1970 GMC truck
Old 03-03-2013, 01:36 PM   #7
jptriumph650
jptriumph650's Avatar
I Had alot of trouble with mine as well. Did you bleed the brakes in the sequence the books say. Plus what helped as well I made a bleeder bottle out a 1liter soda bottle and put some fluid in the bottle and a tube running from the bleeder into the fluid. It worked for me.
jptriumph650 is offline   Reply With Quote
Old 03-03-2013, 02:01 PM   #8
geezer#99
geezer#99's Avatar
Check the brake rod first!
Bolt it to the highest hole.
Old 03-03-2013, 03:59 PM   #9
kevmic28
kevmic28's Avatar
Forgot to say I have a booster on it. All I did was swap masters on the booster.
1970 GMC truck
Old 03-03-2013, 04:58 PM   #10
kevmic28
kevmic28's Avatar
Also checked the brake rod. Its in the only hole in the brake pedal.
1970 GMC truck
Old 03-03-2013, 05:11 PM   #11
1972SUPERSB
1972SUPERSB's Avatar
I am wondering about this too. My pedal seems to go to far and I am thinking the drums need to be adjusted more or brake pedal needs adjusting.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 03-03-2013, 05:29 PM   #12
Boog
laying low
Boog's Avatar
If the truck was like this when you bought it maybe it had the wrong master cylinder on it at that time. The drum/drum master cylinders are different than the disc/drum master cyls.
Excessive pedal travel is most usually caused by brake shoes not adjusted close enough to the drums.
Even if the drums are worn past spec adjusting the shoes out to it will compensate for the extra travel.
I adjust the shoes until the wheel stops turning to seat them then back off until the shoes just barely touch the drum.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-03-2013, 06:19 PM   #13
cdowns
cdowns's Avatar
if you dont make sure the rods are adjusted with the master cylinder and booster as they tell you in the GM factory service manual the brakes tend not to work properly
it is not a just boltup a new cylinder repair
Old 03-03-2013, 11:08 PM   #14
kevmic28
kevmic28's Avatar
If I have time tomorrow Ill try adjusting them again. Wont driving back and forth in forwards and reverse move the adjusters to the right point eventually?
1970 GMC truck
Old 03-04-2013, 12:24 AM   #15
Boog
laying low
Boog's Avatar
Well moving backward and hitting the brakes hard is supposed to ratchet them up but as we all know self adjusters don't always work. The surest method is remove a drum adjust the shoes out to where the drum just drags when pushed back on then install the wheel. Now turn the wheel by hand and listen for the dragging sound. With a tool make any further adjustment through the slot in the backing plate. Move onto the next wheel.
Boog
primer is finer
Old 03-04-2013, 12:39 AM   #16
buckskins4ever
buckskins4ever's Avatar
I am glad you mentioned your Booster. Pull your vac hose attached to your booster and look for fluid inside it. It sounds like your booster has a bad seal and is not performing well enough.
I had the same issue right after installing a new master, and bleeding them.
buckskins4ever is offline   Reply With Quote
Old 03-05-2013, 12:31 AM   #17
kevmic28
kevmic28's Avatar
I should have mentioned I had this problem before I installed the booster.
1970 GMC truck
Old 03-05-2013, 12:54 AM   #18
LSUMurse
LSUMurse's Avatar
I doubt this is the culprit, but I've heard of MC's being tempermental if you don't bench bleed them. Apparently, they can even be next to impossible to completely bleed if not done on the bench first.
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 03-05-2013, 03:59 PM   #19
kevmic28
kevmic28's Avatar
I bench bled it correctly. I may have time tomorrow to work on it after work so I will swap the masters then and see if that makes a difference.
1970 GMC truck
