Old 03-03-2013, 01:35 PM   #1
CopperC10
CopperC10's Avatar
Question Factory style Butt Splice and 1 wire Alt question. Proform 140amp
I have read many many threads including Mads write up on this topic. I have used the search button alot and I need your help. Maybe Vettevet can chime in here.
We are cleaning up the wiring on the 68 and we are at the factory style Butt Splice. I'm going to call the previous owner "dude" to make it easy.
All the gauges worked in the truck when we purchased from dude. I do not know how considering what I found when i untangled the rats nest.
I wish to use that Proform 140amp 1 wire Alt and retain the gauge inside the truck.
I just run a 8 gauge wire from Alt to the butt splice where I also tied in the external regulator red wire. The brown wire went to harness not to Butt Splice. Here is where i am confused. The Blue and White wire were snipped so how was the gauge in the cab working when we purchased from dude?
1968 C10 SWB. GM 350. TH400. 12 bolt. 3:08's Posi
2005 YukonXL 5.3L 4:10's
CopperC10 is offline   Reply With Quote
Old 03-03-2013, 05:40 PM   #2
CopperC10
CopperC10's Avatar
Re: Factory style Butt Splice and 1 wire Alt question. Proform 140amp
I've decided to go with a 10si. Now I need to figure out if I am going to run everything to the junction block or finish at new buss barr by the external regulator. I want the dumby light and gauge to work
Old 03-03-2013, 05:50 PM   #3
CopperC10
CopperC10's Avatar
Going with the 10si is it an option to run the Bat from alt to buss barr or splice and then connect #1 terminal to the brown wire that was connected to the external regulator then jump the #2 to the Bat? Will this work or should I rewire it all to the passenger side junction block?
