Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-03-2013, 01:56 PM   #1
Arekusu
Arekusu's Avatar
NHRA / IHRA Class. What do you run?
Well it just occurred to me that I may have F'ed up. Well maybe not. Maybe I just went off the deep end after building this 454 and decided to look at what drag racing classes there are actually and where I'd fit in. This never popped into my brain until I decided to build the big block.. no way in hell I'd try and run a 292 L6 for time at the strip.
So I guess what class do you guys run when you go race?
Alex
Arekusu is offline   Reply With Quote
Old 03-03-2013, 02:34 PM   #2
Arekusu
Arekusu's Avatar
Re: NHRA / IHRA Class. What do you run?
Ok, I'm guessing GT/T_ (A,B,C,D) http://classracer.com/classes.html
Right now I'm trying to figure out the rules for engines. Like, "X" displacement didn't come in a '64 .. But I know a lot of you guys are running a small block in a year other then '66, so how's that work (for my 60-66 counterparts). Maybe more reading for me. Maybe someone will search this later and find something useful out of this.
Old 03-04-2013, 01:50 AM   #3
dohyde34
bump for ya......
dohyde34 is offline   Reply With Quote
Old 03-04-2013, 03:13 PM   #4
Marv D
Registered Truck Offender
Marv D's Avatar
Your going to find unless you want to chase the class around the country your probably going to be ET racing like 99% of us, not dot.90 or 'stock' class racing.
Most of the monthly / weekly programs ran at tracks are simply ET racers. Get through tech, roll the dice and put number on the window. and hope you cut a liht.
There is a SST and a SG association here in AZ,, but as tracks fall like flies I suspect they will also. Car counts in the AZ SG association was only like 15-20 cars last event I saw them run. (sad)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 03-04-2013, 05:08 PM   #5
Arekusu
Arekusu's Avatar
Hi Marv,
Well thanks for the info. ET racing it is. lol
Alex
Old 03-04-2013, 05:22 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If you run too fast in one bracket while racing ET, they just move you to the next bracket barring you have all the proper equipment on the car for the next bracket. Most tracks will use the current general safety rules as outlined by the NHRA.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-08-2013, 03:48 PM   #7
moggey01
I was involved in Pro Stock , Pro Stock Truck, Comp Eliminator , some Pro Mod . I like the street racing stuff , there is a big following with the heads up drag radial classes now. I would be happy just to make a pass at this point . My project has a long way to go .
moggey01 is offline   Reply With Quote
Old 03-08-2013, 05:32 PM   #8
Super73
Super73's Avatar
I do test and tunes and grudge racing. Track is too far to do any points style deal.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-08-2013, 07:12 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
NHRA S/ST will be my class once i get a handle on the transbrake changeover . I also 7.0 index race and NHRA / IHRA bracket race also .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
