Old 03-03-2013, 04:02 PM   #1
86c20
86c20's Avatar
Question thinking hummer tires
would like to know what it would take to clear 37 hummer h1 wheels? it will help get my rpm down for when i do my diesel swap on my k30 to a detroit 6v53. thaks, mike
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 03-04-2013, 03:24 AM   #2
andrewmp6
Re: thinking hummer tires
Probably a 6 to 8 inch lift rpms depends your gear ratio with those tires.
andrewmp6 is offline   Reply With Quote
Old 03-04-2013, 04:06 PM   #3
86c20
86c20's Avatar
dam 6 to 8 i was hopeing for like 4 lol but it is needed for the 6v53 swap so might be ok
Old 03-04-2013, 09:06 PM   #4
76stepsidechevy
I clear 37x14.50s with a 6" bds with 1" zero rates up front. I wouldn't try it on a 4" lift unless you don't mind cutting fenders or body lift.
76stepsidechevy is offline   Reply With Quote
Old 03-04-2013, 09:09 PM   #5
obijuan
heres six inch with a zero rate moved 1.5 inch forward. lots of room. i also trimme the front fang off the fender.
and a crap load of room on stock wheels
obijuan is offline   Reply With Quote
Old 03-04-2013, 09:13 PM   #6
obijuan
just six inch and 35s
same six inch and the zero rate 1.5" forward but with 37s
Old 03-04-2013, 09:30 PM   #7
83GMCK2500
GHAH! How have I missed that K5? What is that fabulous looking front bumper that you have? Great looking K5.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 03-04-2013, 09:36 PM   #8
obijuan
lol thanks. it has no markings and no identifying things. it appears to have been made by ARB and has styling from that. supposedly from when they were called "aussie"?
no clue really. it came on my truck when i bought it and it is definitely well made and if it was one off it was by a very skilled person. 1-3/4 tubing bent up to press broke 1/4 plate bottom part. it is a winch bumper also under the plate.
i painted it black and put it on my dually a while back. when i sold the dually it was a deal breaker if the bumper didnt go with it.
on topic lol, this is 4 inch and zero rate with 36s
Old 03-04-2013, 10:37 PM   #9
broey
Square
broey's Avatar
I thought hummer tires were 16.5?
Squarebody Syndicate
broey is offline   Reply With Quote
Old 03-04-2013, 11:06 PM   #10
obijuan
that is correct, they are.
Old 03-06-2013, 01:48 AM   #11
andrewmp6
4 inch lift might work if you use some cut out fender flares maybe.
Old 03-06-2013, 11:12 AM   #12
86c20
86c20's Avatar
what do you mean 1.5 forward?? also this is not an off road truck building it to pull trailers and such
Old 03-06-2013, 12:31 PM   #13
mattcrp1
mattcrp1's Avatar
Are you going to run those military take off's? The 16.5" 37's? I had a set of those on my lifted ford and suprisingly they rode well and the wheel turned ok in the parking lot.
mattcrp1 is offline   Reply With Quote
Old 03-06-2013, 01:52 PM   #14
86c20
86c20's Avatar
thats what i am thinking of doing. i know that i will nee to lift the truck some for the motor swap but i dont want to get so high. not really crazy about a 7 inch lift lol
but with 37 tires it helps with trans options
