Old school farmer sheetmetal repair.
Here is some pictures of a truck I picked up last weekend for parts. Sheetmetal repair has sure improved over the years !!
My Build Thread 51 chevy http://67-72chevytrucks.com/vboard/s...d.php?t=437496 48,49,50 Chevy trucks. 41 Olds |
Re: Old school farmer sheetmetal repair.
Wow!! That's a little extreme! Wonder why didn't they just swap out for a used fender.
I just repaired a pair of fenders that weren't that bad but had been poorly repaired. Patent date of April 13 1920 is stamped on one of the riveted pieces! ![]() ![]() ![]() ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
I have had similar fenders, they are a great learning experience but if you value your time it is cheaper to buy a new aftermarket fender. But I would do it again in a heartbeat.
Doug 48 chev LWB pickup 350 turbo400 tri power 48 GMC S10 350 700R4 48 che 5 window 2012 Camero suspension & power train |
I'm seeing that right now on my build. Not as bad but is a fun learning experience. feel the same as you Doug.
![]() ![]() Join Date: Nov 2008
That riveted one might have been a fairly good quality repair in a rural setting, pre the welders-are-commonly-available era.
Back in those days if you want to cut out & replace, did you braze in the repair? I'm sure it took a fine touch with an oxy/acetylene torch. Posted via Mobile Device |
#6 | |
Hey Dan, I still dig out my torches and welding rod when I have a small sheet metal crack that needs welding just for practice!
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#7 | |
#8 | |
Maybe its a dumb question but do these coat hanger repairs stand up over time without cracking? I assume its a low heat weld?
When you are acetylene welding a fender or some other part you try to keep the heat down as much as possible, but you have to get the metal to the melting stage or it wont fuse together. As far as holding up, if you cleaned the area around the weld good and painted it it held up fine. I think most of the famous customs from the fifties and sixties were done with acetylene and they are still around. Guys like Barris and Winfield probably used coat hangars too.
Back in the day coat hangers were made with better quality steel, these days they are made from crap. Mechanics wire works great and leaves the joint soft for metal finishing. Just remember to clean it before welding.
