03-03-2013, 05:40 PM | #1 |
1955-59 Porterbuilt rear drop member rear end?
Currently Have a 1959 Apache and wanting to run the rear dropmember for porterbuilt. Here is the question. I am wanting to run 5 x 4.75 wheels from a previous project. Anyone have any suggestion for a replacement rear end that will have that bolt patter and the right length to fit under the apache and also work with the porterbuilt drop member brackets(im assuming 3 inch axle tube).
Any input is helpful Thank You |
03-03-2013, 06:07 PM | #2 |
Re: 1955-59 Porterbuilt rear drop member rear end?
Porterbuilt is a vendor on this site why not shoot him a PM and ask him directly.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
03-03-2013, 06:13 PM | #3 |
I have contacted them directly, but I was hoping to get other opinions as well.
Posted via Mobile Device |
03-03-2013, 06:23 PM | #4 |
The man to contact is Delmo he has built two trucks with that set up look in projects and built section of this sub forum.
03-03-2013, 07:22 PM | #5 |
Square
poncho used a camaro rear end.
Squarebody Syndicate |
03-03-2013, 07:28 PM | #6 |
67-72 parts collector,…
More important is what wheel will you use?
That will dictate which rearend you use. Or vise versa,...
03-03-2013, 08:06 PM | #7 |
03-03-2013, 09:35 PM | #8 |
Square
no prob. thats what im using for my rear also.
