Old 03-03-2013, 06:20 PM   #1
alyslo
68-71 bbc motor mounts.
Does anyone know why these are so expensive? $200. Can i just install some small block mounts on it? $16.00
Thanks.
alyslo is offline   Reply With Quote
Old 03-03-2013, 07:24 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 68-71 bbc motor mounts.
Yes you can install small block rubbers on the bbc frame stands. Just use a significant washer to cover the larger hole. I used a couple of harmonic balancer washers since they're nice and thick.
I have no idea of where it is now, but somewhere in the FAQ section, I did an article on this very same issue about 8 years ago. If you have a bit of patience, it's here to read. There should be pictures in it too to clarify.
Old 03-03-2013, 07:42 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
I am using the motor mounts and towers that came with the '74 454, they worked out great with the manual transmission and headers. We did have to drill holes in the frame and cradle.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 03-03-2013, 09:31 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here is Kevins thread on the subject...
http://67-72chevytrucks.com/vboard/s...d.php?t=122645
LockDoc
Leon
Old 03-03-2013, 09:35 PM   #5
LockDoc
LockDoc's Avatar
Here is another one...
http://67-72chevytrucks.com/vboard/s...d.php?t=128765
LockDoc
Leon
Old 03-04-2013, 09:46 PM   #6
alyslo
Thanks for the info and pics. I forgot to mension that mine is a 4x4. Will this concept still work?
Old 03-05-2013, 08:34 AM   #7
Tx Firefighter
I can't help you on that issue. 4x4s never came with big blocks so you are going down a completely different avenue than what we were referring to.
There are a good number of guys on here who have done with big block 4x4 thing though so the answers are certainly here if you look for them.
Old 03-05-2013, 12:51 PM   #8
LockDoc
LockDoc's Avatar
I can't help on that one either. That's why it is important to give all the info you can on the vehicle in the first post...
This isn't necessarily just directed toward you, this actually happens a lot.
LockDoc
Leon
Old 03-05-2013, 12:55 PM   #9
Tx Firefighter
Leon, any chance we will get to see you at Pate again this year ?
Old 03-05-2013, 02:26 PM   #10
LockDoc
LockDoc's Avatar
Kevin,
I just checked with the wife and she says we have a family reunion that weekend... Bummer..
LockDoc
Leon
Old 03-05-2013, 08:20 PM   #11
merlin3
i think tx firefighter just solved a huge mystery for me.I think the p.o installed a big block on small block frame stands on my truck.I think that would explain the oil pan hitting the front crossmember and not finding headers to fit.I noticed his oil pan is way far away from the crossmember.
merlin3 is offline   Reply With Quote
Old 03-05-2013, 10:11 PM   #12
alyslo
I'll get the info correct next time. Thanks for your help.
