suspension problems ?????
so working on the truck today i noticed a slight lean to the drivers side looking at it from the front
what parts do i need to look at to find out why springs? bushings? any info would be great so i know where to start |
Re: suspension problems ?????
Park truck on the most level ground possible, snap a few photos so we can get a few sets of eyes to assess the issue.
Causes for a lean to the driver said can be many or a combination of things: eg. suspension parts, panel & bumper alignment, low air on drivers side tire etc. Does a visual check of underside and suspension parts turn anything up? Is suspension stock or modified?
66 GMC Suburban Custom 66 Chevy K10 Suburban |
will do there is no bumper on at the moment so its not that maybe bushings pics to follow
Cab bushings or rear leafs are the most common cause
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Will check them if it's the rear leafs do I just replace them or is there a fix
Posted via Mobile Device |
Location: Santa Barbara, California/Tuscaloosa, Alabama
Seems like a good excuse to start an air bag project!
^^^X2^^^
![]() Join Date: Jun 2010
Have you tried to swap leafs from one side to the other. I hear some say they have done this and it helped. Are the cab mounts and bushings in good shape. Have you done any measuring to see what corner is leaning? If it is the spring I say just replace it. Do you have a spring shop in your area. Did you get any photos yet?
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
Spear and magic helmet!
I had that lean, but it wasn't noticable until after I lowered my truck. Then it stuck out like a sore thumb. I swapped my leafs side to side and it got really close to level. I guess 30 years of the gas tank and driver on the same side is what caused this issue
ok tried to do a leaf swap but could not get the nuts off the u bolts holding the leafs to the axle tried heat and impact wrench so put it all back together and will let it soak with penetrating oil and will try again later
mine does this but i have noticed it does it more when the gas tank is full having only one side tank
