C10 or k10?
So I have a 1972 Chevy short stepper C10 or so I thought. It's 4wd, but it's badged as a C10? Shouldn't it be k10? Can anyone help me with this? Thanks!
Posted via Mobile Device Last edited by 70cst; 03-03-2013 at 09:43 PM. |
![]() Join Date: Jul 2001
Re: C10 or k10?
Fenders and badging can easily be changed. Bodies can be swapped, glove box doors can be changed. Does the cab VIN # match the frame stamped #. Cab VIN will have a "K" for 4wd or a "C" for a 2wd factory production. The frame stamped # should be on drivers side top frame rail near the steering gear box. May have to clean grease and crud off with wire brush to see it. Will be a partial number matching the vin #. Others with more knowledge can give you some more things to look for I'm sure.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Roadtrip!
![]() Join Date: Feb 2003
Re: C10 or k10?
C-10 is the correct badge. The only 67-72s that got a "K" badge was the blazer on 2 or 4wd. Your VIN would have a CK at the beginning if it is a 4x4.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: C10 or k10?
Thanks fellas!! Makes sense now. By the way, do y'all know what weight oil for the differential? It's a 12 bolt
Posted via Mobile Device |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: C10 or k10?
75w90
Re: C10 or k10?
What does that mean! And thanks!!
