03-03-2013, 09:19 PM | #1 |
cam going to provide enough vacuum for brakes?
So bear with me if this is a silly question. I'm building a .030 over 6.0L. Cam specs are 223/230 .634/.608 114+4 will this cam make enough vacuum for my brake booster or do I need to look at hydroboost?
Posted via Mobile Device |
03-04-2013, 01:41 AM | #2 |
meowMEOWmeowMEOW
Re: cam going to provide enough vacuum for brakes?
You have a high enough LSA that the brakes should work pretty much fine; you can always add a small vacuum resevoir if its something your really worried about, but it shouldn't be necessary.
03-04-2013, 09:49 AM | #3 |
Hydroboost?
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
03-04-2013, 05:50 PM | #4 |
meowMEOWmeowMEOW
Hydraulic assist braking system that runs off a different power steering pump and booster. Can lockup just about any set of brakes you can find.
03-04-2013, 07:39 PM | #5 |
Didn't read the last part of his sentence.
I'll go back to my corner of the room now...
