Old 03-03-2013, 10:07 PM   #1
63ChevC10
63ChevC10's Avatar
Please help me identify my I6!
Ok, my apologies in advance because this has probably been covered here a million times over. I just can't seem to figure out anything other than it's a 230-250 out of a 64-76 Chevy/Olds. The engine is currently in my 63 C10 long bed.
Here's the casing number:
3921968
Here's the numbers on the pad near the distributor:
F0527CCG
2 L527678
Here's the numbers back by the starter:
CON2
E260
I'm hoping I put O's where they are supposed to be and zero's where they are supposed to be. Any help is much appreciated!
63ChevC10 is offline   Reply With Quote
Old 03-04-2013, 09:58 AM   #2
1963c-10
1963c-10's Avatar
Re: Please help me identify my I6!
Would have come off foundry conveyer 2 built in May 26, 1970 (E260). Can you get a number off the head? Might help narow it down some. My guess is being built that late its probably a 250. My numbers show 64-76 chevy/old 230/250, which you already knew.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-04-2013, 05:25 PM   #3
kieth
kieth's Avatar
JOLLYS GMC WEBSITE SHOWS PICTURES BETWEEN THE I6 ENGINES, CANNOT FIND THE LINK TO THAT SITE BUT WILL ADVISE WHEN I FIND IT. KIETH
kieth is offline   Reply With Quote
Old 03-04-2013, 06:00 PM   #4
oldblu65
oldblu65's Avatar
Jolly's all inclusive website - http://www.chevytalk.org/fusionbb/sh...hp?tid/187290/
" The lesson is in the struggle , not in the victory "
oldblu65 is offline   Reply With Quote
Old 03-05-2013, 11:49 AM   #5
kieth
kieth's Avatar
Guess I was wrong, no differences showed up from the 230 to the 250......thanks for finding Jolly website though...Kieth
Old 03-05-2013, 10:08 PM   #6
63ChevC10
63ChevC10's Avatar
Thanks everyone. I appreciate the responses and research! Based on the fuel pump that was on it when I bought it, I'm going with a 250 for now. 1963 C-10, I agree that it's probably a 250 and I will take down the numbers off of the head the next time I have the valve cover off.
Old 03-05-2013, 10:33 PM   #7
Vernski
The only difference I can find externally is the fuel pump is closer to the distributer on the 230, the fuel pump on the 250 is towards the center of the motor...Vernski
http://www.6066gmcguy.org/Inline6.htm
Vernski is offline   Reply With Quote
Old 03-06-2013, 01:10 AM   #8
BadaSs_Cal
BadaSs_Cal's Avatar
I have a picture in my build thread of a known 250. Well bored over now its more like a 252 ;p
My understanding was the only way to tell was physically measure the bore, or was it stroke???
Either way I think physically they are the same motor.
Oh btw, new to this side, I was just a 69-72 guy, but rescently picked up a 3/4 ton, 66 GMC.. Long step.
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 03-06-2013, 02:30 AM   #9
Vernski
Well that's what I thought also, but check the pictures on Jolly's site see if you see a difference there between the 2 motors illistraighted...Vernski
Old 03-06-2013, 11:37 AM   #10
60-66
60-66's Avatar
3921968
F0527CCG
2 L527678
ON2
E260
Your engine originaly came from a 1970 Impala Chevelle Camaro and or Nova. The CCG code only shows up as 250 Six Cylinder 155 horse power with a manual transmission. This is straight from a 1971 Chevrolet parts book. Normaly the suffix code only shows up for one body style but not this one.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-06-2013, 12:43 PM   #11
kieth
kieth's Avatar
Vernsky, get the bifocals out you were comparing a 250 to a 292, I could see no difference in the 230 vs 250 ha ha Kieth
Old 03-06-2013, 10:39 PM   #12
63ChevC10
63ChevC10's Avatar
Thanks 60-66! Sounds like I'm the proud owner of a 250! Definitely good to know for future parts, etc.
