03-03-2013, 10:12 PM | #1 |
Side Moulding Clips?
who has the best deal for the good side moulding clips? i'm not going to use those plastic stick on deals. thanks
03-04-2013, 10:17 AM | #2 |
Re: Side Moulding Clips?
Upper or lower moudling? Year?
I ordered mine from Classic Parts to put on my used set of upper and lower LWB 69-72 trim because they were the cheapest, and the lower clips were all excellent. They were indistinguishable from the originals and went on perfectly. The upper bolt on clips were also great and worked perfect as well. The upper snap-in clips were another story. They were worthless. They were not at all like the originals and didn't work at all. I ended up throwing them away and using the adhesive type. I don't know if the other vendors sell a different design, but I would check those upper snap in clips before you buy if that's what you need. Good luck.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
03-04-2013, 10:24 AM | #3 |
thanks curt, 72 swb upper and lower
03-07-2013, 09:09 PM | #4 |
Curt, what was the part number of the trim clips you used? Was it for the individual clips or a set?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
03-08-2013, 12:18 PM | #5 | |
Here are the part numbers from Classic Parts: For the good ones that worked: Upper trim bolt on: 62-882 Lower trim bolt on: 62-876 Lower trim snap in: 62-884 And here's the upper trim snap in clip that didn't work at all for me: Upper trim snap in: 62-875 If you buy the bolt on clips, you'll need to buy the speed nuts to go with them, part 62-888. If anyone finds an upper snap in clip that works, I'd sure be interested in hearing about it. Good luck!
03-08-2013, 12:46 PM | #6 |
C/10 junkie
Does anyone know where to get the 67-68 stick on molding clips?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
