Old 03-03-2013, 11:53 PM   #1
rs74
rs74's Avatar
Have issue with rear shock mount and flip kit
I was looking today at the rear shock mounts after I put the WC flip kit on. The shock mount is right up against the flip kit plate. I won't be able to get the bolt through and the nut on. Surely I am not the only one to run into this. What is the fix? Not the best photos.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-04-2013, 12:13 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Have issue with rear shock mount and flip kit
Get rid of the. Overload spring then run a shock mount extender welded to the old mounts.
Much smoother ride then
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-04-2013, 12:18 AM   #3
DREAMER1
DREAMER1's Avatar
I got a shock mount extender...gotta have it, cause your factory shocks won't fit unless you wanna buy new shorter shocks. My extender was a bolt in job that was hassle free.
DREAMER1 is offline   Reply With Quote
Old 03-04-2013, 12:21 AM   #4
rs74
rs74's Avatar
Do either one of you guys have pics of your setup?
Roy
1987 R10 shortie
Old 03-04-2013, 12:24 AM   #5
INSIDIOUS '86
Old 03-04-2013, 10:12 AM   #6
rs74
rs74's Avatar
Originally Posted by INSIDIOUS '86 View Post
Are those just held on by the one bolt? Thanks for posting the pic.
Roy
1987 R10 shortie
Old 03-04-2013, 10:22 AM   #7
silvereagle07
silvereagle07's Avatar
I have the same setup as above with the overload spring removed. I installed the shock extenders before I installed the flip bracket. I had to notch the bracket for the head of the bolt for the shock extender. It doesn't take much off . Just mark and grind it out .
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
