Old 03-04-2013, 12:36 PM   #1
JJAB
Compression Ratio
Guys, got the opportunity to bolt up a 408 LS stroker in a swb checvy c10. Thing is, the the compression ratio of the motor will be 11.5 - 1. I know running premium octane is a must, but what other issues if any, will I run into with this type of compression.
JJAB is offline   Reply With Quote
Old 03-04-2013, 05:49 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Compression Ratio
11.5 isn't scary high, just higher than average. I'd make sure you ran the good quality premium 93 (not that california 91 trash). If you can't get it or you think you'll still have pinging with all that Texas heat, its pretty easy to build a Methanol setup to spray if you want the insurance. DIY meth kits can be as cheap as $50-75
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-04-2013, 07:07 PM   #3
JJAB
Thanks!! I spoke with the piston manufacturer and their tech department said that a .062 thick head gasket could reduce the compression to 11.3 to 1. I guess every little bit helps.
Old 03-04-2013, 09:17 PM   #4
69Beauty
69Beauty's Avatar
I would not use a thick head gasket to bandaid to lower compression. it may seem like a good idea but there is a reason for the quench to be ideally between .035-.045 or so. increasing this distance increases the possibility of detonation. i would just make sure you have a good cooling system and a good tune and you should be fine. corvettes runs 11.0 or so nowadays and thats OEM stuff so you should be just fine.
1969 C-10 LWB 388 SBC Vortec Heads 10:1 Lunati 60103 cam Weiand intake Quadrajet Carb 12 Bolt 3:73 posi 700r4 Hedman Headers
1998 Dodge Ram 1500 Reg. Cab Long Box 4X4 5.9L 183k miles
1956 Ford F-100 Longbed with Original 272 and 3OTT
1995 C1500 ECSB 6.5 Diesel 4l80e (Camper puller)
1997 Dodge 3/4 ECLB V10 (MPG machine)
69Beauty is offline   Reply With Quote
Old 03-05-2013, 11:16 AM   #5
JJAB
OK, thanks for the information. ALWAYS GOOD INFO HERE!!!!!!!!!!!!!!!!!!!!!!!
