Old 03-04-2013, 06:14 PM   #1
Keckdl
Keckdl's Avatar
Speedo off, help
Is there a way to retard or advance a mechanical speedometer? My gears in the transfer case (drive/driven gear) are correct for my tire to transmission but it is off approximately 18-22 % roughly.
If there is a way to adjust the speedo or not I appreciate the input.
Thanks,
Dan
83 Chevy K10 Scottsdale, ZZ4, TH700r4, 4.10, 33"
Keckdl is offline   Reply With Quote
Old 03-04-2013, 06:59 PM   #2
Ski-me
Ski-me's Avatar
Re: Speedo off, help
Yes you can by swapping out either your drive gear, driven gear or both. Your cable should go into your transfer case. There is a site around here but can't find it yet. I'll post back if I find it......
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 03-04-2013, 07:01 PM   #3
Ski-me
Ski-me's Avatar
Here is one website:
http://www.performanceautomatic.com/...ter-gears.html
You'll need to first determine what you have (number of teeth) by figuring out the colors of both gears.
- Jeff
Old 03-04-2013, 07:03 PM   #4
Keckdl
Keckdl's Avatar
I have done the trans gear calc and it said the setup I have is correct for th700/np208 and 4.10 gears with 33" tires but it is still off.
This is why I ask if you can adj the speedo.
Thanks for the reply
Dan
Old 03-04-2013, 07:16 PM   #5
Ski-me
Ski-me's Avatar
You might be able to go in and have the speedo re-calibrated but I would suspect that the speedo gears were still off.....don't know.
You could try swapping the easy gear and see if that helps?!?
- Jeff
Old 03-04-2013, 07:17 PM   #6
Ski-me
Ski-me's Avatar
If you are really bored you could convert it to electronic.....but that's a whole other subject! I did it and now my speedo is spot on with 35's.
- Jeff
Old 03-04-2013, 07:53 PM   #7
maxxxy
maxxxy's Avatar
When I first read the title, a very disturbing image popped into my head.....
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 03-04-2013, 08:36 PM   #8
Keckdl
Keckdl's Avatar
Truthfully I would love to make the conversion to electric. That would simplify things greatly! Right now I want to fix what I have because it is cheaper.
On a side note; what is involved in the conversion?
Dan
Old 03-04-2013, 08:37 PM   #9
Keckdl
Keckdl's Avatar
What do you adjust when you re-calibrate it?
Dan
Old 03-04-2013, 09:51 PM   #10
geezer#99
geezer#99's Avatar
Get a ratio adaptor.
http://www.transmissioncenter.net/sp...____va.htm#350
Old 03-04-2013, 10:29 PM   #11
Ski-me
Ski-me's Avatar
I don't know if you could do it or not. I did mine on an NP241 transfer case.....
http://coloradok5.com/forums/showthread.php?t=296187
- Jeff
Old 03-04-2013, 11:05 PM   #12
Keith Seymore
Keith Seymore's Avatar
Originally Posted by geezer#99 View Post
x2.
I like to throw an adapter on there; it "skips directly to the answer" instead of doing all the intermediate mathematical steps.
The last time I did this the adapter I needed was laying on the workbench (no purchase necessary).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
