Old 03-04-2013, 07:02 PM   #1
cmcardle75
16" dually wheels to replace 16.5"
Will any 16" steel wheel clear the brakes on a 1978 P30 dually RV originally fitted with 16.5" wheels? Or do you need to go 17" to be sure? I won't be able to try out in advance and want the same wheels front and rear so the spare will fit either. If you think 16.5" tyres are hard to find in the USA, try Europe.
cmcardle75 is offline   Reply With Quote
Old 03-04-2013, 07:12 PM   #2
cmcardle75
Re: 16" dually wheels to replace 16.5"
P.S. One of the ones I'm thinking of is the Accuride 29587.
Old 03-04-2013, 07:57 PM   #3
Ziegelsteinfaust
I believe all chassis that used the 16.5 are capable of going to 16's with out a problem. The .5 tire was so they could have truck only tires, and later they just swapped to 16's.
I would check rockauto.com for C30 measurements to verify.
Ziegelsteinfaust is offline   Reply With Quote
Old 03-05-2013, 01:02 AM   #4
meter swinger
meter swinger's Avatar
I've run both sizes on my dually.
meter swinger is offline   Reply With Quote
