Old 03-04-2013, 08:47 PM   #1
Boss hawg
Bent tie rod!
Does anyone know if a bent tie rod end would throw the wheel base out an inch? I wouldn't think it would cause that much of a difference but I don't know. I put a corvette front in my 54 and it has 116 1/2 on one side and 117 1/2 one the other. The side with less is the bent side. If you measure to the lower ball joint you get to same measurement from both sides.
Boss hawg is offline   Reply With Quote
Old 03-05-2013, 03:50 AM   #2
andrewmp6
Re: Bent tie rod!
Any kind of alinement spacers on the side that is wider?
andrewmp6 is offline   Reply With Quote
Old 03-05-2013, 09:43 AM   #3
Boss hawg
Re: Bent tie rod!
There are! I will check into that when I get back out to the truck. Thank you for the suggestion. I bought a new tie rod to so maybe after taking care of both of those it will fix hopefully.
