wheel size question
I am in need of some new wheels. I have a old set I was going to throw on until i get the ones I want. will 15x10 wheels 4.5 backspace work on my 72 c10.... I figure fronts will be the biggest issue... can they work with out rubbing ect...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Re: wheel size question
anybody
![]() Join Date: Feb 2001
Here is a bump for you.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
I had 15x10 rallys with 4.5 bs with 275x60x15's on the rear of my '70 c10 and they fit good, but they would not fit up front.
On average the front is 3" wider than the rear. There is also a clearance issue with the tie rod. Which diameter wheels are you going to buy
Posted via Mobile Device |
hey thanks, I appreciate it.. thanks all
A 15 x 8 with 4"bs will fit up front. What wheels are you getting? Are you staying with a 15". Or going bigger.
20' Daredevil (Ret)
![]() Join Date: May 2003
You'll probably have to grind a little material off the front calipers to get any 8-lug 15" wheel to fit up front.
