Turbo 400 question
I have a 68 C10 with a turbo 400 transmission. I just installed the driveshaft and linkage. It doesnt have a dip stick yet and I also need to put fluid in. I started the truck to see if it would go into gear but it didnt do anything. I didnt want to leave it running or try for very long because of the no dipstick and fluid so I only tried twice. I'm new to this so any help would be awesome!!
Re: Turbo 400 question
Don't do that! Put fluid in and hope you have not already ruined the trans. Fluid is what makes the bands clamp which makes it shift. You may need a new trans.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
It wont do anything without fluid. you need dipstick and fluid before running it.
Mark 67 c20 custom camper 55 Olds 2dr hardtop 96 mustang 11 dodge nitro |
Crap ok. I honestly did it for 3 seconds so hopefully it's still ok.
#5 | |
Good luck. |
Got it. It does actually have fluid but its needs to be changed. I do need a dipstick however....
Didnt mean to scare anybody but I want to correct myself. It does have fluid but its old. I meant to say it didnt have new fluid. It does not have a dipstick so I was curious would this make it not engage?
#8 | |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#9 | |
I would still drain out the fluid, and refill with fresh. Try it again, if not working then you should at least try to do a trans flush. |
No leaks at all. I have a dipstick coming tomorrow. I will put that in and drain the fluid and put some new fluid in. Thanks!
