Old 03-05-2013, 09:20 AM   #1
Beemerdoc
Tach operation with cluster swap
So, I am working on this 81 stepside and put in a cluster from a 70 something big truck to get a big tach with a small fuel gauge. I got the cluster pinned out correctly, and everything works as intended.
The tach had a separate harness; Black wire (ground), pink w/ black stripe (ignition + current) and a brown (signal). Hooked it all up, and tach goes past the 5000 mark and doesn't move with engine revs. I read where there was a filter needed, and bought one to go between the brown wire and the distributor. No change.
Question: Am I having trouble because the tach originally took a signal from the coil in a points based system and I have HEI? Is there a way to convert the signal? Anyone been here and can help me out?
Thanks in advance for your help.
Beemerdoc is offline   Reply With Quote
Old 03-05-2013, 12:21 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Tach operation with cluster swap
is it for a 6 cyl?
how high do the revs go?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-05-2013, 12:34 PM   #3
Beemerdoc
V8 396...not the stock motor. I have no idea what the big truck had for an engine.
Old 03-05-2013, 12:55 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
got any pics of it
i understand some 6 cyl diesel tachs have less revs "written" on the front
and only go to 4000 not 5000
you mention 5000 so thats sounds right
maybe a part number on the board back...
John
