Old 03-05-2013, 09:59 AM   #1
register
register's Avatar
prepping for carpet....
I'm removing the old rubber floor to get ready for install of carpet.(not yet purchased)
and this is what I have found surface rust, nothing to bad no holes just surface rust what would you guys do? thoughts and opinions would be greatly appreciated!!!!
sorry for bad picture will get better ones
register is offline   Reply With Quote
Old 03-05-2013, 10:05 AM   #2
Lattimer
Lattimer's Avatar
Re: prepping for carpet....
I would hit it with a rust converter and at least primer before putting the carpet down.
If my floors had looked like that I would have jumped for joy!!!
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-05-2013, 10:06 AM   #3
register
register's Avatar
would you grind off all the rust to get to bare metal then hit with rust paint?
Old 03-05-2013, 10:08 AM   #4
Lattimer
Lattimer's Avatar
I'd just wire brush it, then do rust converter, then paint. Most of the converters just require no loose scale.
Shawn
Old 03-05-2013, 12:32 PM   #5
big d's red67
big d's red67's Avatar
x2
1967 swb 454 cid 700R4 trans SOLD
2006 Chevy Trailblazer SS
2013 Camaro RS convertible the wife's
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248
big d's red67 is offline   Reply With Quote
Old 03-05-2013, 12:42 PM   #6
Billett
Billett's Avatar
x3. Consider some sound deadener while you have nothing in there. I put FatMat and Reflectix in mine and its much quieter and warmer.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-05-2013, 12:45 PM   #7
register
register's Avatar
The ACC carpet that I'm looking at has mass backing would you also you sound deadener?
Old 03-05-2013, 12:50 PM   #8
Lattimer
Lattimer's Avatar
I think its useful to do both. I put down a paper backed asphalt type sound deadener, then jute padding and rubber flooring. Huge difference in noise compared to bare steel floor....LOL.
Rubber floor I bought sucked, so it will soon be replaced with ACC carpet.
Shawn
Old 03-05-2013, 01:37 PM   #9
Billett
Billett's Avatar
I'd do both. It's not expensive unless you go with Dynamat
Will
2024 Toyota Sienna
Old 03-05-2013, 09:24 PM   #10
KyFarm
KyFarm's Avatar
I'm about to buy the MIP floor from LMC. What type of rubber floor did you use?
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 03-05-2013, 10:02 PM   #11
54belair
54belair's Avatar
In addition to all the good ideas so far-----Id go one step further. (I hate rust)
When you clean and coat the inside floor with whatever rust encapsulator you prefer-- Id also clean the under side of the flor and coat it also--sealing both sides of the metal.
Then,,, do some checking as to why the floor is rusting---is water comming in around rubber grommets on the firewall? Do you have a windshield rubber leaking?
Try to eliminate the source as well as repair the damage.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 03-05-2013, 10:10 PM   #12
Lattimer
Lattimer's Avatar
I got the one from LMC that is supposed to be the heavy duty and extend all the way to the back wall. I was not impressed.
Shawn
