03-05-2013, 12:27 PM | #1 |
Where did you put your spare tire?
(1965 C10)I would like to put my spare tire between the frame rails at the rear of the truck but I also am interested in moving my gas tank out of the cab. Any ideas. Where have you put your spare?
03-05-2013, 12:43 PM | #2 |
Re: Where did you put your spare tire?
what's a spare?
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
03-05-2013, 12:48 PM | #3 |
In the shed.
Tire and road technology is so great today that there isn't a lot of need for a spare. If I am going on a long trip I will throw the spare in the bed, otherwise it sits in the shed.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
03-05-2013, 12:51 PM | #4 | |
YOU ARE NOT from Louisiana, and you live dangerous
http://s1299.photobucket.com/user/jb...23904108567829 |
03-05-2013, 12:55 PM | #5 |
Your question is one of the issues why I retro-fitted my tank back into the cab, that the PO had moved to under the bed. I like the spare tire in the stock location.
Think carefully before you move your tank, the move creates many issues that need to have solutions engineered for like: filler location and type, spare tire location, rear tank ground clearance, etc. I like my tank behind the seat, and I like my spare under the bed, it is rarely used and out of the way. good luck
past trucks: 1980 C-10 Silverado SWB 1961 C-10 custom cab LWB 1966 C-10 custom cab LWB |
03-05-2013, 12:55 PM | #6 |
If you use an original Suburban/Panel tank you can store your spare AND have a rear tank. They're not reproduced so you have to find an original one. If you get the filler neck and fill door you can then put the fill cap in your fender, not in the middle of the bed floor.
03-05-2013, 01:33 PM | #7 |
VictoriaHardware, you have an pics of what the factory suburban/panel tank looks like with the spare in a truck? Or does anyone have any pics? There must be a legitimate reason having one of these tanks with spare is not chosen over the aftermarket tanks.
1965 Chevy short-step side, work in progress.... ............................____ ..................______l/___\____ .................|_/(0)\_ll____/(0)_l. |
03-05-2013, 01:40 PM | #8 |
bbadfred
Don't have one thats what road service is for. Since I am not going to change a tire on my diesel pusher I have road service that covers all my vehicles motor home, all three trucks, cars and Motorcycles for like 90 bucks a year. So far they win cause I have not had a single claim!!
03-05-2013, 01:48 PM | #9 |
Senior Enthusiast
Since my truck rarely ventures far from home, for several years I just carried a can of Inflataspare in the glove box. I figured if that wouldn’t get me home I’d call AAA. Subsequently we’ve decided to take some longer trips, so I went back to carrying a spare clamped to the right front bed floor with a Camaro bracket and j bolt. Of course in my truck this is hidden under the hard cover.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
03-05-2013, 01:48 PM | #10 |
1965 Chevy C10, 2005 4.8L/4l60
Aaa!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-05-2013, 02:00 PM | #11 |
My preference is the factory fender mount system
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
03-05-2013, 02:22 PM | #12 |
Mine is inside the fleetside bed using a OEM carrier. Too old to crawl underneath on the side of the road...
03-05-2013, 02:54 PM | #13 |
Same reason I did the spare tire conversion. Seems everytime I need a spare its raining or im near the worse mudhole in the county
03-05-2013, 03:27 PM | #14 |
mine comes in a can
03-05-2013, 04:00 PM | #15 |
Hope you never have to clean a rim thats had that installed. When I got my truck, It took several hours just to get one rim cleared of that instaflat in the can gunk off.
03-05-2013, 05:20 PM | #16 |
I have a can in my toolbox, but I really couldn't tell you why. Even if I had a flat I wouldn't use it. That stuff doesn't always work and as mentioned above its a PITA to clean. Right now I don't have a spare in the truck, but once I get another set of tires for the extra rims I have I'll probably just leave one in the bed under the tonneau. Gotta love the 8' bed haha
03-05-2013, 09:26 PM | #17 |
Here are good pictures from another thread- http://67-72chevytrucks.com/vboard/s...d.php?t=545525 Short wheelbase pickups and Suburbans and Panels share the same basic chassis. You can see the "cutout" in the lower rear where the spare tire fits. It's a 20 gallon tank.
Below is another pirated picture showing the fill door placement. It wouldn't be hard to imagine the door area being grafted into a pickup fender- either fleet or step side. Would make for a clean installation. |
03-05-2013, 10:15 PM | #18 |
I understand that on many new cars, the buyer has the option to get a spare tire---!!! Seems they use a "spare-in-a-can" of some sort as standard, and maybe cheaper(?) than if one exercises the real spare option?
Been meaning to look further into that, and prolly will as soon as I have a flat away from home. I've also been considering buying a 'space-saver' tire/wheel that is smaller & should fit into a smaller, metal suv-spare cover; maybe even have uphols. shop make an elasticized, color-coordinated custom cover to fit it, laying/lug wrench & jack into center of wheel wrapped upside down. Shouldn't look too bad lying up close to the cab. *Note to VictoriaHardware: Good idea, I think, re: fill lid--I put one in my '66 stepside, outta a van, and it really looks factory. Sam Last edited by luvbowties; 03-05-2013 at 10:19 PM. Reason: added info |
03-05-2013, 10:46 PM | #19 | |
MusicMan70 1961 GMC Suburban |
03-05-2013, 11:03 PM | #20 |
mines mounted in the bed with a tire cover. Simple and effective.
Rockin' a '66 and loving every minute of it |
03-05-2013, 11:46 PM | #21 |
Anybody ever try to mount a new style tank inside the frame?? was thinking about this but hadn't attempted it yet. Will try once I get the bed off.
03-06-2013, 12:13 PM | #22 |
Check The Champ, Demonstrator
My preference is inside the Fleetside box. This was an original option. You can use a mount in the 70's and 80's though you'll need to cut the height of those. I'll be putting hubcaps on the spares to dress them up a bit. No crawling under the frame for me.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
03-06-2013, 12:42 PM | #23 |
I plan on putting a space-saver inside the back of the 'Burb, but also have an inflater set up to connect to the air tank, just in case. The truck will have one in the bed.
03-08-2013, 09:59 AM | #24 |
I am consider trying to build a saddle tank on the drivers side but not sure how large a tank it would be. Then put a fuel door in the bed like my old 83 chevy pickup.
08-17-2015, 12:53 PM | #25 |
I am thinking of trying to fit one behind the bench. Anyone ever done that?
