Old 03-05-2013, 12:47 PM   #1
Steve ATL
Sloppy Steering
Hi folks - new member and first post.
I just picked up a 1980 K10, bought from Texas and shipped here to the Atlanta area. The previous owner did quite a bit of body work so the truck looks great, but had some issues upon arrival like the brakes not working.
The shop I had do the brakes also replaced the steering box and tie rod ends to attempt to correct very loose steering, but it is as bad as when I took it in only now the wheel is not centered. I have about 4-5 inches of slop in the steering.
Sure would appreciate some direction here - thanks all! If anyone knows of a good shop in the north Atlanta area I would appreciate that as well.
Steve ATL is offline   Reply With Quote
Old 03-05-2013, 12:57 PM   #2
Low87
been here longer than Liz
Low87's Avatar
Re: Sloppy Steering
Try this;
http://forum.73-87chevytrucks.com/sm...c,12525.0.html
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 03-05-2013, 01:09 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Sloppy Steering
A lot of aftermarket boxes that are rebuilt are still as sloppy as the old. Granted a 4x4 will never get sharp steering the steering wheel still shouldn't have that much play before I it moves the linkage.
Redhead steering is a company that puts steering boxes together with meticulous detail and do nice work. About to put one on my truck myself
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-05-2013, 01:27 PM   #4
Steve ATL
Re: Sloppy Steering
Thanks Greg - the sloppy steering is caused by those 4 tilt bolts being loose?
Old 03-05-2013, 01:37 PM   #5
Keith Seymore
Keith Seymore's Avatar
Re: Sloppy Steering
"Steering wheel not straight" is easy: you can adjust the fore/aft drag link (from the knuckle to the gear) without affecting any other alignment settings. Just adjust the overall length of the drag link by moving the sleeve until the steering wheel is level going straight down the road.
Sloppy steering - not so easy. Make sure all of the components are good, consider getting the new gear that Insidious recommends. Or - you can also tighten up the preload and overcenter adjustments of your existing gear (either still in the vehicle or with it removed). Detailed instructions are in the service manual.
After that get the alignment checked. I like a lot of caster on K/V trucks (like 10 degrees) to maintain straight line stablility so you might consider that after you've got the rest of the steering system sorted out.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-05-2013, 01:45 PM   #6
Keith Seymore
Re: Sloppy Steering
Excellent steering column rebuild link - but I don't think it has anything to do with your problem.
K
1979-1986
1986 - 2019
Old 03-05-2013, 01:45 PM   #7
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: Sloppy Steering
My 91 k5 still turns as sharp as my 2011 armadA
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-05-2013, 01:57 PM   #8
Skunksmash
Skunksmash's Avatar
Re: Sloppy Steering
So those rebuilt steering boxes from Oreillys are not a good idea?
Also to the OP, there are other things to check besides just the steering box. Such as the tie rod ends, and the pitman arm. My pitman arm was wore out and when I replaced it, it took about 1.5 inches of play out of the wheel. Just something to think about.
Skunksmash is offline   Reply With Quote
Old 03-05-2013, 10:51 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Sloppy Steering
sloppy rag joint can add some play too
mine got a whole lot better,just doing that
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-06-2013, 01:25 AM   #10
INSIDIOUS '86
Re: Sloppy Steering
I personally haven't had experiences with store brand but I have read many threads where they are marginally better than the original worn stuff
Old 03-06-2013, 04:24 AM   #11
cory d
cory d's Avatar
Re: Sloppy Steering
Originally Posted by Low87 View Post
NO THANKS
cory d is offline   Reply With Quote
Old 03-08-2013, 03:33 AM   #12
Skunksmash
Skunksmash's Avatar
Re: Sloppy Steering
Originally Posted by cory d View Post
NO THANKS
I know lol
Old 03-08-2013, 12:15 PM   #13
75chev4x4
75chev4x4's Avatar
Re: Sloppy Steering
Check your shackle bushings in the frame on the rear of the front keaf springs. This and a number of other things helped tighten mine up.
75chev4x4 is offline   Reply With Quote
Old 03-09-2013, 12:16 AM   #14
Skunksmash
Skunksmash's Avatar
Re: Sloppy Steering
If you do what they call a "dry park check" you can find every last sloppy joint that you need to replace. Have someone turn the wheel side to side while you watch all the steering components. When the truck isn't running. Watch them turn the wheel, and watch when the parts start to move. You'll be able to see exactly what lags behind, when they start turning the steering wheel. You'll probably have to start at the rag joint. I think that's the first failure point.
